Forum Coordinators: Kalypso
Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Visit the Carrara Gallery here.
I don't believe that the eariler GI content was re-saved into a format the "respects" the new scaling options available on Carrara - however, it was bundled with C6. In C5, it was one-size-fits-all. In C6, you now have Small, Medium and Large. Consequently, all scenes would need to be retooled. I don't think that was done. :-P Personally, I feel it's a minor issue since rescaling groups make this a pretty easy fix.
thank you for your answers guy's
what you do? scale you down vicki or scale you up the carrara things? Is there no option to get the workspace bigger?
i did a render and dont scale vicki because she had a lot clothes on but than i choose the sky with the small clouds and the clouds are around her belly piercing (looks funny but not that i want)
that can not be the right way to scale in every scene all poser content down ????? and the proportionen make me mad :-(
any useful advices for me please ?
jenny, I first loaded the character (V4.1). then I loaded a scene. unfortunately, the two methods I tried don't work. double-clicking an indoor scene in the browser causes a new document to open (without V4.1). dragging an indoor scene from the browser to the document window causes a tiny indoor scene to appear next to the giantess V4.1. is there a special method to add a preset scene to a document which already contains V4.1, in such a way that V4.1 is correctly positioned and correctly sized, with respect to the preset scene?
I am having the same trouble with trees, the Willow is the size of a Sequoia, and when I try to render, the trunk looks like a sand dune a night!!! And nothing works, except to resize everything object by object. I am getting a %#@*!^ headache, my eyes can’t stretch that far apart!
Well if you have imported the DS runtime to your section of the Browser(simply called content and is empty)Or even your Poser runtime..then anything you take from your content will fit with your characters.
The problem occurs for me when I take a character from the content and try to marry it with an object from the Carrara supplied content in the browser.
The Carrara House is only 8 or nine inches tall. I exported it in OBJ to Amapi 7 to scale it to the right height using its measuring tool. Then exported the house back into Carrara 5 in the past.
I am not sure what was going on with my system, but I got black screens, no renders, disappearing menus, and imports at every size and description, 5.9 feet, 3.9 feet, and other sizes. When I boot the system today CP6 works and the ghosts are gone. It is not the graphics card or drivers, but do suspect the Visual Studio 5 redistributables did not register correctly with the system.
If interested, I am running Vista x64. Will use Aiko 3 as base figure;
Aiko cr2 imports at 5.9 feet in 3000 ft scene, imports at 5.9 feet in 30 ft scene, and imports at 70.84 ins. in a 30 inch scene.
Thanks Mark, I am one of the Beta testers for NVidia Vista Drivers, so went to that area immediately.
Because the VS5 installed into the base Application folder rather than into
the WinSxS folder, and everything returned to normal when I shutdown and booted later, I would assume the VS5 redistributable didn’t shake hands with the Registry in a friendly manner.
It is all back to normal and working now, no more glitches.
Thanks for your help. Now I have to read the manual all over again!
may somebody can give me advice about the scalling for my poser content?
it is really a nice thing to import the content via the carrara browser but my Vicky and Aiko are really a littel bit oversized for Carrara 6 - I need help please
