Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
SpawnCharacter uses the current state of the vertices to generate a new morph. Actually, it spawns a morph target, just like one could do manually.
It should not ignore magnets, I'll have to look into that when I have time.
When you spawn a morph target manually, a morph delta for EVERY vertex is generated, even if the delta is zero. SpawnCharacter strips out deltas that are smaller than 10 to the power of (- morph precision).
TBH, a morph precision of 8 is a waste. A morph precision of 4 would mean that deltas smaller than 0.25 millimeter would get stripped, So a morph precision of 5 (strips deltas smaller than 0.025 millimeter) should be good enough for just about anything.
I put this functionality in the script to make the resulting .pz2 files smaller.
hi! Q:"It should not ignore magnets, I'll have to look into that when I have time." well, may i send you the morph-setting pz2 and the mags of one of my v3 characters? then we can compare the results - maybe there is something wrong on my end of the line ... ;) Q:"When you spawn a morph target manually, a morph delta for EVERY vertex is generated, even if the delta is zero." i am sorry but i have to disaggree in this point. i still use p5 in 99.9%, my system's too old for the newer versions (to rotate the camera around v3 is a slideshow). and p5 writes only deltas for the vertices that actually have been moved. is that different in p6/7? i haven't tried it yet... Q:"I put this functionality in the script to make the resulting .pz2 files smaller." definitely a good and smart idea! the only thing that worries me is the seams between bodyparts (like the crappy area around v3's sternum).
first of all: thx to svdl, not only for this script which is a valuable timesaver, but also for all the other goodies! there's 2 things about this script i just don't understand... 1. it seems to ignore magnets. does it 'simply' merge already existing and nonzeroed morphs or am i doing something wrong? as a workaround i spawn morphs manually and run the script with these new morphs... 2. ...but when i compare the new pz2 with the cr2 i see that the morphs often have less deltas. is this due to the 8-digit-limit? tia A.
