Wed, Feb 26, 1:38 PM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 24 11:54 pm)
Subject: Not quite invisibles
IsaoShi ( ) posted Sun, 11 May 2008 at 7:52 AM · edited Sun, 05 January 2025 at 3:58 PM
Can anyone help with this, please? The linked image (a straight on shot with two mirrors, which I did just to illustrate the problem) shows Rhiannon's Elsa Wylde with a pose applied that makes her skirts transparent. Only when I come to render, this is the result. I have tried all sorts of things in the material room, even completely deleting the image map connection for the skirt and manually setting its transparencies to 1, but it still comes out like this. Does anyone have any ideas what is causing this, please? Thank you! Izi
"If I were a shadow, I know I wouldn't like to be half of what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki Murakami)
geep ( ) posted Sun, 11 May 2008 at 8:21 AM
It appears that you may still have the "Specular" and/or "Highlight" options adding to the render.
Make sure those parameters are BLACK and set to zero (0), also, and see if that helps.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Marque ( ) posted Sun, 11 May 2008 at 8:49 AM
If there is a pose that is supposed to make them tranparent I would contact the vendor and ask them what the problem might be.
IsaoShi ( ) posted Sun, 11 May 2008 at 9:00 AM
Thank you Marque, you are right, and I have just done that!
I have seen renders where this works fine, so it must be me. But hopefully the vendor will be able to point me in the right direction.
Thanks to Dr Geep too, I'll try those things in the meantime.
Rhiannon ( ) posted Sun, 11 May 2008 at 9:48 AM
Hi Izi ... sent you an IM.  :-)
IsaoShi ( ) posted Sun, 11 May 2008 at 1:21 PM · edited Sun, 11 May 2008 at 1:23 PM
Just to round this off, the strange 'shadows' of the invisible skirt (and top) parts were caused by the ambient occlusion I was using with my single IBL light. As I wanted AO in my piccie, the answer was simply to make the skirt and top invisible to raytracing, and - poof! - AO shadows done gone.
There were no shadows at the default render settings, as raytracing is switched off, so no AO.
Thanks to Rhiannon (vendor) for a prod in the right direction!
Izi
IsaoShi ( ) posted Sun, 11 May 2008 at 1:56 PM
Hee hee - silly me! I redid the render with the two mirrors, and of course her reflection is starkers now! Oh well, she might as well join the rest of the gang and rip everything off anyway.
Or I'll just forget about using a combination of AO, invisible clothing parts, and reflections. sigh the limitations we artists have to endure.
Stop sniggering.
