Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 11 2:16 pm)
Attached Link: "Creating Cartoon" pictorial compliments of Dr Geep Studios
*(click image to view full size) (**click** **the link above the** **image** to view the complete pictorial - 29 pages)Hi Pete,
Some of the info in this pictorial may help.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Attached Link: http://www.renderosity.com/mod/bcs/index.php?ViewProduct=49574&vendor=288865
in addition to geep's excellent advice, dimension3d has a script for poser toon settings, allowing easier use of poser's "toon render" wacro.Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=2885157&ebot_calc_page#message_2885157
Once you have your character set up, go to the material room, and hold down shift and click the 'Set Up Toon Render' Wacro button to toonify your character. That's what I did for the picture in the linked thread, is that the type of toon effect you are after? I did it in Poser 7, but it is also doable in Poser 6.Attached Link: olivier's art materials
well I find you need a quick easy way if you are making lots of panels for a comic, and the easiest workflow for me (and looks good too) is shaderworks combined with olivier's art materials. Love esther
There is a whole section on cartoons in this thread:
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2722867
say." - Ghandi
Attached Link: daz studio thread
you should look at this daz studio thread too. Love estherI aim to update it about once a month. Oh, and it's free!
Quote - Once you have your character set up, go to the material room, and hold down shift and click the 'Set Up Toon Render' Wacro button to toonify your character. That's what I did for the picture in the linked thread, is that the type of toon effect you are after? I did it in Poser 7, but it is also doable in Poser 6.
For what few toons I've ever done, the built in Wacro has suited my needs just fine. I can only see buying other toon shaders if I were planning on marketing a comic strip on a regular basis. I'm just not that funny. :tt2:
the poser 7 toon render wacro is very good IMVHO. one reason that it's very hard for
folks to learn how to ink comix is that inkers use a combination of edge-falloff and scene
lighting techinques as they visualise the scene, hence it's non-intuitive for newbies.
fortunately, poser has an excellent edge-blend node that is fabulous for doing the ink
work IMVHO. this can then be augmented by poser's own toon line function, if desired.
I've never come across a toon render from Poser that emulates the changes in line weight you'd get with traditional (or digital) inking. If anyone has an image that's got an example of this I'd be pretty excited to see it and find out how it was done. I know a few comic book artists who have worked on titles like Spawn and Star Wars comics who have used Poser to help them complete their work but they usually have to take it beyond the render's ability to convery line weight inside a paint app, Illustrator or Manga Studio.
Idon't think I did any postwork in those last two pics, just straight shaderworks applcation of olivier's shader using his smooth shaders.
yes - that outline goes all the wy aroundthe figure, but the art material shadersdon't do that
love esther
Miss Nancy, that's it exactly. Variation in line width is essential to keeping an 2D illustrated comic interesting to look at. So it'd be pretty important to be able to mimic it if all you're using is Poser. What would be even cooler would be to be able to apply specific colors for the lines around specific objects...sort of like what's being done in todays 2D and 2&1/2D cartoons. Just idle rambling here. If that's a Poser render Miss Nancy, then I think it's close enough to what I was asking that I'd be satisfied with it (either way, it's neat). - it would also prove to me that I need to spend more time in the material room.
ive found ONE texture in fact so far that looks amazing and "lit up" as it should... the others are VERY dark and totally different than what the texture should look like in general.
any idea why this is?
also- i assume Miss Nancy you tore into that image in photoshop correct? poser can't get anywhere near that fidelity in a toon render, at least not that ive seen lol. sure would be nice... but until it does i think the toon renders do pretty well. its just odd that i can only use one texture set for V4
yeah, dark, it's a P7 toon render with the lines drawn using APS path tool.
but it's just a matter of time before one of the node gods posts a guide on
how to use the poser edge_blend node to get some fabulous falloff shaders
in poser. the toon shader function should work o.k. with ordinary textures,
provided they're plugged into the diffuse channel and there isn't alotta bling
or fastscatter or any of that fancy alternate diffuse stuff AFAIK.
Darkworld, the problem is you need the ambient colour to be white. Then you should find all of the textures you want to use work. The problem is transmapped clothes and hair etc are going to look bad and not work properly with your poser method I think. I really think the easiest and nicest option is shaderworks combined with olivier's art materials found at rdna.
Love esther
I like this look a bit better as I think it looks like marvel comic cover style.
Love esther
ps I quite understand. when making thousands of comic panels you don't want to be spending all day fiddling around
Hello.
I have been trying to create some toon renders in poser 6 but with out much luck.I wonder if somone would put me on the right track please.
regards.
Pete
