Tue, Jan 7, 12:18 AM CST
Renderosity Forums / DAZ|Studio
Welcome to the DAZ|Studio Forum
Forum Moderators: wheatpenny Forum Coordinators: Guardian_Angel_671, Daddyo3d
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 06 9:16 pm)
Subject: How to get Poser Props (PP2) with morph (PMD) to work in DAZ Studio
LBAMagic ( ) posted Sat, 13 December 2008 at 8:07 PM · edited Sun, 05 January 2025 at 12:19 AM
Some Poser Props files (PP2) that have a separate morph file (PMD) and do not work in Daz Studio. However there is a way to fix this. You will need a Text editor (I used WORD for this example). Follow the two simple instructions in the image (click image to enlarge).
MeInOhio ( ) posted Sun, 04 January 2009 at 7:49 PM
So the original line wouldn't be there anymore, correct? And will the file still work in Poser? Thanks.
Whimsical ( ) posted Fri, 16 January 2009 at 9:55 PM
Id be interested in knowing this too in regards to whether the file would still work in poser or not :)
MeInOhio ( ) posted Sat, 17 January 2009 at 2:29 PM
It didn't work for me anyway when I tried it. Probably did something wrong but I couldn't figure it out. There is suppose to be a script for allowing PMD files to work in DS. I'll post a link when I find it again.
Whimsical ( ) posted Sat, 17 January 2009 at 11:24 PM
Thanks that would be hugely appreciated re the link to script :)
MeInOhio ( ) posted Sun, 18 January 2009 at 7:05 AM
Here is the link.
http://www.4shared.com/get/60703148/f35033a5/InjectPMD_2313_PC.html
I haven't tried the script yet. I know modifying the file didn't work for me, but maybe I did something wrong.
You can also turn off PMD in the preferences and then save your morphs and it won't create the extra PMD file. Not sure what you would do if you didn't create the morph and can't save it again. There's probably a way, but I don't know how yet. I was using one of those magnet packages to fit hair to M4. My saved hair would work in Poser but not in Studio. That's when I found out about PMD files and how to turn them off and save the morphs without them. They work in both programs then. But maybe with the script we wouldn't even have to do that.
Whimsical ( ) posted Sun, 25 January 2009 at 12:49 AM
Thanks for that, appreciate you posting the link.
Ok.. silly q time if i may :-)))
How do you turn off PMD's and save morphs without them?
An asking incase I have no joy with the script :-))))
Any and all help much needed at this stage lol :-)
MeInOhio ( ) posted Sun, 25 January 2009 at 4:32 PM
There's a setting in preferences for turning off PMD, then you just save the morphs normally. I'm no expert in this area. I was using that Hair conversion package for M4. I converted some hair and it worked in poser but not in DAZ Studio. That's when I discovered PMDs.
Whimsical ( ) posted Sat, 31 January 2009 at 1:22 PM
Cheers :)
LBAMagic ( ) posted Fri, 06 March 2009 at 12:50 AM
Quote - So the original line wouldn't be there anymore, correct? And will the file still work in Poser? Thanks.
Hi MelnOhio, sorry for not getting back earlier. I forgot about this post.  The change I made to the make the PP2 file to work in D|S does not affect it from working again in Poser (I have Poser 7 so I can't say for earlier versions).
LBAMagic ( ) posted Thu, 02 April 2009 at 7:43 PM · edited Thu, 02 April 2009 at 7:43 PM
The Inject PMD script provided by DeltaX15 at DAZ Forum is for Pose PZ2 files. Unfortunately does not apply to Prop PP2 files. I have tried.
At the moment the only way for DAZ Studio to load the PMD morph into it's associate Prop PP2 file is to first modify the Prop PP2 file as I have noted above.
Note: I have ALL of DeltaX15 scripts. They are fantastic and a definite MUST have for D|S. I believe DAZ should put them in a standard on their next release of D|S.
P.S. Sorry again for my slow responses.
