Sat, Sep 21, 4:58 AM CDT
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Forum Coordinators: Kalypso
Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
Visit the Carrara Gallery here.
Carrara Free Stuff here.
Visit the Renderosity MarketPlace - Your source for digital art content!
Subject: Help with Photo Realistic Renders
  • 1
  • 2
Jedi_Padawan ( ) posted Mon, 22 June 2009 at 9:57 AM
Sure. That's the image with the light-reflecting-wall turned invisible:
That's it with with a visible light-reflecting-wall, but therefore the backdrop isn't visible anymore:
And here's the preview of the settings in the assembly room:
Still very low render settings, but before I continue, I'd love to figure out this light problem.
Thanks a lot for your help!
~Sassy~
GKDantas ( ) posted Mon, 22 June 2009 at 2:11 PM
I tried something like that here, and look that the way that you want to scatter the light, the background image will get washed. I think the better way is to render and add the image as a post processing in Photoshop or another 2D software...
Follow me at euQfiz Digital
GKDantas ( ) posted Mon, 22 June 2009 at 2:31 PM
Another way is inverting your spot to right light the kitchen and add a glow channel with the backdrop image.
Jedi_Padawan ( ) posted Mon, 22 June 2009 at 4:48 PM
Marcelo, I intend to relay on the basics of Populus' image here:
www.renderosity.com/mod/gallery/index.php
What do you think which technique he'd used there? I was hoping for something like in the image this thread started with and which Sandy reworked. ๐Ÿ˜•
GKDantas ( ) posted Mon, 22 June 2009 at 10:23 PM
I asked populus about that... lets wait for the answer.
Populus ( ) posted Mon, 22 June 2009 at 11:49 PM
Hi! this image: http://www.renderosity.com/mod/gallery/index.php?image_id=1643367&member
use a spotlight (with softshadows) just outside the window, directed inwards. Indirect lighting turned on and a big white wall on the opposite side of the spot (inside the room, not visible in this camera angle) for those photons to bounce from. A hdri for backdrop but not used for lighting, you can use an normal image for backdrop, work just as well. Hope this helps a little, but these kind of scenes are veeeery tricky to calibrate...took me several hours just to balance the light...
GKDantas ( ) posted Tue, 23 June 2009 at 2:22 PM
Thanks Populus for the tips.
Jedi_Padawan ( ) posted Tue, 23 June 2009 at 3:54 PM
Thanks a lot for your tips, Populus, I'll try that when I'm at home again.
And thanks for asking him, Marcelo!
~Sassy~
  • 1
  • 2
