Wed, Dec 4, 9:16 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 4:13 pm)
Subject: can the fog atmosphere thing float only the ground?
MistyLaraCarrara ( ) posted Fri, 24 July 2009 at 2:56 PM · edited Mon, 18 November 2024 at 11:57 PM
can the fog atmosphere thing be made to float near the ground?
as far as I can tell, it only makes the whole scene white-ish.  which I can't think of a use for.
they used ground smoke a lot in the old Lost in Space tv show. danger will robinson, danger
IsaoShi ( ) posted Fri, 24 July 2009 at 3:41 PM · edited Fri, 24 July 2009 at 3:42 PM
Do you mean Depth Cue, in the Atmosphere node? This works simply by adding the depth cue colour to the diffuse colour of the surface being rendered, at a strength depending on its distance from the camera.
So I'm fairly sure the answer is no, it can't.
I have seen a prop smoke/fog product, but I can't remember where.
"If I were a shadow, I know I wouldn't like to be half of what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki Murakami)
IsaoShi ( ) posted Fri, 24 July 2009 at 3:55 PM
Wait!
There is a way you can have the DepthCue effect stronger near the bottom of the image, and weaker towards the top. Just plug an inverted v_Texture_Coordinate node into the DepthCue Color channel.
It may need lots of tweaking, maybe with extra math nodes for positioning, to match the ground in your scene, however.
ockham ( ) posted Fri, 24 July 2009 at 4:12 PM
You could get there with a properly transmapped square or cyclorama in front of the scene.  Here's a quick attempt that doesn't have a sharp enough bottom, but at least the bottom is clearer than the top.
My python page
My ShareCG freebies
ockham ( ) posted Fri, 24 July 2009 at 4:13 PM
The material setup.  The Image Map is a gradient made in PaintShop.
My python page
My ShareCG freebies
IsaoShi ( ) posted Fri, 24 July 2009 at 4:23 PM
Hmm... just ignore my suggestion above. I discovered (should have realised) that it applies the gradient to each separate material that it renders, not to the whole view.
stewer ( ) posted Fri, 24 July 2009 at 5:35 PM
Use the P node, not the texture coordinates. The y component is the height of the shading point. I wish I this stupid laptop keyboard had a print screen button so I could show you the shader setup...
stewer ( ) posted Fri, 24 July 2009 at 5:38 PM
file_435222.txt
Rename the attached file to end with .mt5, that shader should be a starting point for experiments.
bagginsbill ( ) posted Fri, 24 July 2009 at 8:04 PM
See also:
http://www.runtimedna.com/forum/showthread.php?t=35521
and
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3412281&ebot_calc_page#message_3412281
The second one I posted a shader with precise control of the fog height and variation. Useful when you know you want it exactly X inches above the ground.
Shader setup is there.
bagginsbill ( ) posted Fri, 24 July 2009 at 8:09 PM
Stewer is being helpful answering questions today. But some days he's busy.
I just wanted to point out, as I've done before, that the quickest way to get a material question answered is to assume I've already answered it. Please understand this is not ego - it's a simple fact. You can find topics with answers fast this way. Not necessarily every answer in the universe, but it's a good bet for your first search.
Go into the forum search, and use "bagginsbill" as the author, both here and at RuntimeDNA.
That's how I found those threads above - searched for "atmosphere" with me as author.
IsaoShi ( ) posted Fri, 24 July 2009 at 10:09 PM
In the RDNA thread someone suggested plugging an fBm node (or maybe Clouds) into the P-node y-channel to give more vertical variation. This is using a near-white fBm.
But I really posted this test render because it demonstrates something I've noticed before about atmosphere rendering - both depth cue and volume - that I haven't seen explicitly mentioned anywhere else (although it most probably is and I just didn't find it).
It is that atmosphere rendering stops at the first raytrace bounce. So no volume is visible in the reflections.
