Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 6:22 pm)
Turn off your IK's
Sorry, IK stands for inverse kinematics. I'm drawing a blank which menu they are under, but I believe it is character.(I'm in the middle of a render so I can't check sorry) Uncheck the ones for the feet.
The default character is SimonG2, when loading A3 I'm replacing the existing figure and after I write Aiko3 instead of SimonG2
Now Figure>Use Inverse Kinematics nothing is ticked
Must I do this every time?
What I would suggest is deleting everything from your scene then set up your blank scene as your preferred preference and save. Exit Poser and restart, it should start a bit faster and come up with a blank scene.
Now when you load any figure, such as A3, it should load without the foot problem.
You will still have to turn off the IKs due to Poser turning them on.
There is a cr2 hack that keep the IKs off so long as you don't save the figure back to the library.
don't remember the wording off hand, sorry. Maybe some else does.
Quote - What I would suggest is deleting everything from your scene then set up your blank scene as your preferred preference and save. Exit Poser and restart, it should start a bit faster and come up with a blank scene.
I don't understand how to begin with a blank scene?
The problem is you used "replace figure". When you do that, it saves the current pose values of the existing figure, deletes it, loads the new figure, and then applies the previous pose to the new one.
When you do this with figures that have different rigging, you mess it up.
You only use "replace figure" with like figures. For example, replacing a naked Simon with a clothed Simon. (Simon Casual)
The proper way to get rid of a figure is to delete it. Then load the figure you want.
The suggestion to save a blank scene as your default preferred state is just so you won't have to delete the default figure every time you start Poser.
Default figures are a stupid idea. Noobs need to learn to load a figure - that should be the first thing that happens. As it is, you are being forced to learn a two step process, and to learn that you should not be using the (unfortunately obvious) one-step process.
The IK cr2 hack, courtesy of Jim Burton
How to turn of Inverse Kinematics Forever! by Jim Burton on 6/1/04 11:34 [Printer Friendly]
For those who don't know how, here is the E-Z way:
Open the Figure as the first one you have opened after starting Poser (or pull down File, New). This is to preserve the figure as :1, incidently.
Turn off the Leg Inverse Kinematics (Figure, Use Inverse Kinematics, click both legs off)
Resave the figure under another name- "Vicky 3 No IK" or whatever.
In your favorite text editor or whatever, open the CR2 and search for "inkyChain LeftLeg". Change it to read inkyChain Left Leg (with a space). (Figure CR2s will be found in Poser/runtime/libraries/character/figure folder).
Do the same with inkyChain RightLeg (inkyChain Right Leg)
Save the CR2.
E-Z, what? ;-) You now have the option to turn it on if you like, but it doesn't automatically open with it on. This isn't new information, but I thought it might be helpful to some. I seldom use IK myself.
Lior, you live close by to me. Call me if you have these problems: 03-551-5260
dph
STOP PALESTINIAN CHILD ABUSE!!!! ISLAMIC HATRED OF JEWS
Oh well, I'm lonely and bored, and would love to talk to just about anyone about Poser & Posette, and my developing Graphic novel, so go ahead!
dph
The CR2 may be corrupted but even so, you should follow the advice given above.
First thing I do with a new installation of Poser is delete the figure and generally set things up the way I want. Then save this as my default start up. It's also a good idea to save it to one of the UI dots just in case Poser goes completely Tango Uniform.
Quote - The CR2 may be corrupted but even so, you should follow the advice given above.
If this ,cr2 is corrupted, why Daz have not made the correction?
It seems I have to uninstall and to install Poser again
No, the CR2 could have been corrupted on your machine. Sometimes it happens. No need to reinstall Poser, either. Delete and reinstall the Aiko base figure would be all you need to do. You could always re download it from DAZ, just in case your installation file is knackered.
Other than that, follow the advice given by others to either start with a blank scene or to delete the default figure before loading Aiko.
Thank you for your help.
