Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 7:36 am)
Did you install Poser into the "Program Files" folder? If you're using Vista or 7 that combined with UAC will be causing you all sorts of problems, the best thing you can do is reinstall Poser outside the "Program Files" folder after backing up the runtime, then copy the runtime back into the new Poser folder.
Windows 7 64Bit
Poser Pro 2010 SR1
Gabriellebri: You probably also have to click the V4 updater in your !DAZ folder in the Libraries. (Or on your desktop if it's still there)
In 'properties' of the updater you find the path that locates to the *.bat file in the !DAZ folder, check the path and see if it's correct new one and not the old one.
I am so frustrated! I managed to get most of my things installed on Poser but now there are certain things that wont work as before..My victoria Morphs ++ refuse to work right.. Wet and wounded wont show up at all even if I install into the Runtime.. I am really regretting upgrading my computer at all..Groannnn. Is any one else having the same probs as I am??
Bri
