Wed, Nov 13, 11:20 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: How do you keep the jeans on the figure?
charlesatlas ( ) posted Thu, 19 August 2010 at 8:14 PM · edited Mon, 04 November 2024 at 11:45 PM
Still another situation.  I am using James and in his clothing folder he has conforming jeans.  When I click on them they appear but dont exactly conform to him.   The tennis shoes are not fitting at all..and to make it worse when I select a James pose..either he bends and the jeans stay standing or the jeans bend and he stays standing.   Please advise and thank you.  Would also like some understanding of conforming vs dynamic.
geep ( ) posted Thu, 19 August 2010 at 8:42 PM · edited Thu, 19 August 2010 at 8:42 PM
Select the jeans ...
... then use the menu "Figure" >>> "Conform to..." >>> James.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
hborre ( ) posted Thu, 19 August 2010 at 8:48 PM
Yep, what geep posted.  You really didn't conform the comform clothing.
charlesatlas ( ) posted Fri, 20 August 2010 at 11:56 AM
AHHHHHHH..thank you both very much...and duh..I cant believe I forgot that.
geep ( ) posted Fri, 20 August 2010 at 12:00 PM · edited Fri, 20 August 2010 at 12:01 PM
Hey Charlie,
No sweat ............... Happens to the best of us .............. from time to time. :biggrin:
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
charlesatlas ( ) posted Fri, 20 August 2010 at 4:51 PM
Hello
That doesnt appear to work.  I increased the mesomorph on James and then hit conform and the pants had tons of holes in them..does it only work when James is his normal size?  If so how do I conform them to a slightly larger James?
charlesatlas ( ) posted Fri, 20 August 2010 at 5:00 PM
Also when I applied a pose where James is sitting...holes appeared in the crotch area which isnt exactly what I had in mind..please advise and thank you.
geep ( ) posted Fri, 20 August 2010 at 5:07 PM
Bend Body parts???
cheers,
dr geep ... :o]
edited 10/5/2019
charlesatlas ( ) posted Fri, 20 August 2010 at 5:49 PM
Dont understand..do you mean use bend body parts?  Thanks.
geep ( ) posted Fri, 20 August 2010 at 8:15 PM
Yes ... if Bend Body Parts is OFF then you can get gaps when a figure is posed.
cheers,
dr geep ... :o]
edited 10/5/2019
TrekkieGrrrl ( ) posted Sat, 21 August 2010 at 9:35 PM
 Some poses, especially radical ones  like sitting MAY create pokethru. The easiest way of dealing with it is to make James' hip/thighs/whatever pokes thru invisible.
And unless the clothing contains the necessary mrophs, it will only fit a figure in it's default, unmorphed stage.
MyCat ( ) posted Sat, 21 August 2010 at 11:06 PM
Quote - And unless the clothing contains the necessary mrophs, it will only fit a figure in it's default, unmorphed stage.
Morphing Clothes can fix a lot of that.
