Wed, Nov 20, 6:43 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 20 6:12 am)
Subject: Pose Dots
Vanzagar ( ) posted Sun, 22 August 2010 at 11:17 PM · edited Wed, 20 November 2024 at 6:33 AM
Can't seem to get "Pose Dots" working, tried pg.44 of the manual...
To use Memory dots:
Set up your pose, cameras, and/or interface (UI) the way you 1. want them.
Use the pull-down menu to select the dot type, as described 2. above.
Click an empty memory dot. This dot will appear full, as shown 3. to the right:Figure 4.13
To use a dot, simply click it. The stored settings are applied to your scene. To clear a memory dot (delete its information and make it appear empty again), press and hold [OPT]/[ALT] while clicking the memory dot you wish to erase.
Works for UI dots, but if I save a pose to a dot then move the animation slider change pose, then move animation slider more, and select the dot I just saved, the pose is not copied to my new animation frame, is there a trick I'm missing here?
Thanks,
Vanz
ps. UI dots work fine, I can quickly select between multiple UI's, but for some reason I can't make the Pose dot work?
markschum ( ) posted Mon, 23 August 2010 at 12:01 AM
It worked fine for me in Poser 7 , however on two occasions it didnt work until I reselected the figure.
Remember to set keyframes .
wingnut1 ( ) posted Mon, 23 August 2010 at 5:19 AM
Quote - ...To clear a memory dot (delete its information and make it appear empty again), press and hold [OPT]/[ALT] while clicking the memory dot you wish to erase.
Thanks, that helped me out.
EnglishBob ( ) posted Mon, 23 August 2010 at 9:07 AM
I think I'm having the same problem. In Poser 6, I could copy a pose from one frame to another by saving it to a pose dot. Now, in Poser 7, that seems not to work - the pose dot saves, but applying it does nothing. It may possibly be saving frame 1 every time, irrespective of the actual frame number set, but I haven't done any experiments yet to try and narrow it down.
As a workaround I save into the pose library instead. I keep a library category called "Saves" which is purely for temporary use, and can be cleared out once the project is finished.
TrekkieGrrrl ( ) posted Mon, 23 August 2010 at 10:34 AM
 There's also the option of "Memorizing" it with Edit->memorize->figure
Fwiw the pose dots works again in PP2010, I just used one the other day.
markschum ( ) posted Mon, 23 August 2010 at 12:47 PM
I use the pose library as well, I can never remember what I put where with the pose dots.  O also tend to cut and paste keyframes instead of applying a pose , its just a work method I got used to.
EnglishBob ( ) posted Mon, 23 August 2010 at 5:40 PM
I just tried it on P6 and P7, using James and Simon respectively and the stock poses, and it worked. Maybe it only fails when you need it to work... :(
Quote - There's also the option of "Memorizing" it with Edit->memorize->figure
That doesn't do what's wanted here though TG. Memorize sets the default pose of the figure, i.e. the one you get when you select Restore from the same menu. I suppose it could be used as a pose memory, but at the expense of breaking the figure's default pose which could be important if you use IK.
Quote - I use the pose library as well, I can never remember what I put where with the pose dots.  O also tend to cut and paste keyframes instead of applying a pose , its just a work method I got used to.
That sounds useful, but I have to admit I don't know how to copy a complete keyframe, and messing about in the keyframe editor didn't get me anywhere. I suppose I could always read the manual, but when did that ever work? :)
Vanzagar ( ) posted Mon, 23 August 2010 at 10:31 PM
Quote - I just tried it on P6 and P7, using James and Simon respectively and the stock poses, and it worked. Maybe it only fails when you need it to work... :(
I'm working on P8, is there a trick, like copy/paste? I move to a frame, hit the dot, then move to another frame, press the dot again and nothing happens? I even try to set a keyframe before pressing the dot and nothing happens...
Copying frame actually works okay in the animation palette... I'd still like to get he dots working though...
Vanz
EnglishBob ( ) posted Tue, 24 August 2010 at 4:24 AM
No trickery, no. Here's how I used to do it:
  • Go to the frame which has the pose I want.
  • Make sure the figure is selected.
  • Click on an empty pose dot. (and check that it "lights up")
  • Go to the frame where I want the pose.
  • Click on the pose dot that I just saved to.
  • Et voilà...
That's what I did last night in P6 and in P7, and it worked. I used to do it all the time, mainly when I wanted to use dynamic clothing on an existing scene, and had to transfer the pose to frame 30 so I could zero the figure at frame 1.
Except that now, it doesn't always work. Mainly late at night when I just want things to work, dammit, so I can finish up and go to bed.
Yeah, I'd like to be able to rely on the dots again. I'll continue looking into this.
