Mon, Nov 18, 6:39 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 18 12:40 pm)
Subject: Translate/Pull Tools locked in Poser 7
Clemenceau ( ) posted Mon, 13 December 2010 at 9:05 AM · edited Sun, 01 September 2024 at 5:02 AM
I'm sure this question has been asked but I cannot find a way to search the forums!  Please don't hate on me if it's here and I can't find it - I did try.......:-(
Anyway,  can someone please help with this question?  I don't know if I've toggled something on/off but the Translate/Pull Tool buttons now cease to function in any Poser scene.  The manual doesn't help with this problem either.  I've been using them successfully for several months now but can't move things around in the scene if the buttons don't work and there isn't any other workaround.
I've rebooted my computer since this problem occurred and it hasn't changed anything,  so I'm flummoxed,  short of re-installing the program entirely.
Many Thanks
KageRyu ( ) posted Mon, 13 December 2010 at 10:27 AM · edited Mon, 13 December 2010 at 10:30 AM
If this behaviour is primarily in one scene, it might be that you have locked the actors. Try going into the figure and object menus and making sure that they are not locked.  If this is happening in multiple scenes I am at a loss, but it might be a python script interfering with the program, or something in the config files got corrupted.  You might want to head on over to Smith Micro's tech support and drop this question on them - though I can almost gaurantee they will say that it is corrupt config files, and instruct you to delete all your preferences and configs (that is almost their canned answer to any odd behaviour, and may or may not fix the issue).
You can skip right to that step by going here and following the directions: http://support.smithmicro.com/cs/smkb.cfg/php.exe/enduser/std_adp.php?p_faqid=2076&p_sid=BRNz9qhk&p_lva=2097&p_accessibility=0&p_redirect=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0zNjUmcF9wcm9kcz0mcF9jYXRzPSZwX3B2PSZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0x&p_li=#
To search Renderosities forums, AFAIK just type your search terms into the Search Renderosity box at the top right of the page, and it will search galleries, blogs, profiles, products, and forums for those terms.
I know this isn't a solution, but I hope this information is helpful.
The New HD Toaster from Wamco toasts bread more evenly and acurately than Standard Toasters. Take advantage of the FULL resolution of your bread and try one today, because if your toast isn't in High Definition, you are not getting the most of your toast!
Clemenceau ( ) posted Mon, 13 December 2010 at 11:00 AM
Hello,
Thanks for the prompt reply.  I will check out the link at Smith Micro in the meantime.  I will say that it is not one scene,  but every scene,  including new scratch ones.  I can however,  use both these buttons within the Materials Lab.
I actually don't have any preferences set that I'm aware of.  I'm using it right out-of-the-box.  No matter whether I load old scenes I created in Poser 4 or brand new scenes native to Poser 7 - those two buttons only will not work EXCEPT in the Materials Lab.
Seems like something has been corrupted because they worked fine until a few days ago.
Thanks again.......
bantha ( ) posted Mon, 13 December 2010 at 12:11 PM · edited Mon, 13 December 2010 at 12:12 PM
Do you have a space navigator from 3dConnexion? If yes, then calibrate or remove it. The problem you describe can be caused by it. I searched for days until I found the solution.
A ship in port is safe; but that is not what ships are built for.
-"Amazing Grace" Hopper
Avatar image of me done by Chidori
Clemenceau ( ) posted Mon, 13 December 2010 at 12:36 PM
No,  I don't.  I am running BOINC client with some scientific applications (they rely heavily on the GPU for processing) but I've used them for 2+ years and I shut them down when I'm running Bryce or Poser.
Haven't installed any new programs and no reason comes to mind.....
CyberDream ( ) posted Mon, 13 December 2010 at 6:58 PM
delete your poser.ini file.
Poser will generate a new one when you restart it.
The location of the file will vary on operating system and other installation options.
Clemenceau ( ) posted Tue, 14 December 2010 at 6:43 AM
The instructions at the link worked.  I delete Poser.ini and UIPrefs.xml,  reloaded my runtime folders and it worked.
Obviously something had gotten corrupted.
Many thanks!
