Sun, Feb 16, 6:23 AM CST
Vue F.A.Q (Last Updated: 2025 Jan 30 6:52 am)
Subject: Vue9 Esprit Gamma
GeneralNutt ( ) posted Wed, 11 May 2011 at 1:56 AM · edited Thu, 05 December 2024 at 2:30 AM
Is there a way in Vue 9 Esprit to change the gamma in and out to 2.2 from the 1.8. I seen the spot in the picture export to change the gamma, but that wouldn't be changing the textures input gamma, before rendering, would it?
bruno021 ( ) posted Wed, 11 May 2011 at 2:46 AM · edited Wed, 11 May 2011 at 2:50 AM
In Esprit you can only output to either a gamma of 1 or 1.8,  no gamma input option. If the necessary nodes are present in the function editor, you can add a Color/gamma node between the colour output and the texture node. Problem is global gamma of the render (atmosphere/procedural colours) will not have the same gamma as your textures.
GeneralNutt ( ) posted Wed, 11 May 2011 at 10:17 PM
Thank you for your response. I have the advanced graph add on, but like you said that's only a partial solution. I will look into how to do it in the mean time, but is there a version of VUE that does allow the gamma correction change?
bruno021 ( ) posted Thu, 12 May 2011 at 1:41 AM
Yes, Infinite and xStream.
GeneralNutt ( ) posted Thu, 12 May 2011 at 2:24 AM
Ug! Well thanks for the reply, but that won't be anytime soon.
