Sun, Feb 2, 1:22 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 9:10 pm)
Subject: Reflections
Sheedee ( ) posted Tue, 17 July 2012 at 3:24 PM · edited Sat, 01 February 2025 at 4:49 AM
I have been struggling with this issue for a long time and i have no idea how to solve it.
The render on the left is done with default poser lights and i added a chrome material on the choker...and i like how her skin looks...the only disatvantage is that the chrome material that i have applied to the choker cant be seen at all.
Now the render on the right is has the same default poser lights...but i added BB env sphere in order to get reflective effects...and it works...the chrome on the choker can really be seen now...but now the disatvantage is that i dont like how her skin texture color has changed...and the reason it has changed is because i added the env sphere.
The real question:  is it possible to preserve the same skin texture color from the the render on the left and still have the chrome stand out like the render on the right...with out using the env sphere?...because the env sphere obviously produces great reflections...but at the same time it has its own light meaning that it somehow washes over any other lights that you have in the scene...in other words is there a way of achieving the same reflective results that the sphere produces...but with out the sphere?...
thanks for viewing.
witchdidi ( ) posted Tue, 17 July 2012 at 3:36 PM
If you're using PoserPro 2012, under the properties tab for the environment sphere, untick "Light Emitter" option.
Be mad...until proven genius.
Sitting quietly in the corner does not make one the class fool.
- Didi
RDNA Store
vilters ( ) posted Tue, 17 July 2012 at 3:40 PM
Correct; Bb's shere is self lit.
So? What does that tell you?
it adds light to your scene
Solution is to reduce the intensiy of your other lights present in the scene.
When I use BB's sphere, I mostly use only one infinite light set at something between 50 and 60% intensity.
Experiment and start from this info.
vilters ( ) posted Tue, 17 July 2012 at 3:42 PM
Uncheck "light emitor" will make you loose most of its advantages.
But you can control the intensity with the HSV value.
Sheedee ( ) posted Tue, 17 July 2012 at 3:47 PM
I took away the light emitter of the sphere...and now it looks like this...no good!...still with default poser lights.
bagginsbill ( ) posted Tue, 17 July 2012 at 6:06 PM · edited Tue, 17 July 2012 at 6:07 PM
If adding the sphere with light emitter off changes the lighting, then you must be using IBL + IDL. Is that true?
And none of us with long experience with Poser have any idea what "default Poser lights" means. First of all, the defaults keep changing. Second they are so bad we delete them immediately.
hborre ( ) posted Tue, 17 July 2012 at 6:36 PM
And default Poser lights are set for depth map; you need raytracing for proper reflections.
Miss Nancy ( ) posted Wed, 18 July 2012 at 4:48 PM · edited Wed, 18 July 2012 at 4:50 PM
your icon is very nice, sheedee - like zeus about to smite those still using depth maps!  you may have some bad diffuse/IDL settings, as seen in nostrils, elbow fold, lips.  maybe you could show them your render settings.  they may also want to see the skin settings.
cspear ( ) posted Thu, 19 July 2012 at 3:27 AM
Also it looks like the chrome shader may be questionable - can you post a screenshot of the setup?
PoserPro 11 - Units: Metres
Adobe CC 2017
