Mon, Jan 20, 12:15 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: Hair Room materials: transmapping
Believable3D ( ) posted Sun, 12 January 2014 at 3:05 PM · edited Mon, 13 January 2025 at 3:59 AM
Is there a way to generate a UV map/template from hair room materials? I am creating eyebrows and want more control over placement of hair growth than is provided simply by following the lines of the group.
______________
Hardware: AMD Ryzen 9 3900X/MSI MAG570 Tomahawk X570/Zotac Geforce GTX 1650 Super 4GB/32GB OLOy RAM
Software: Windows 10 Professional/Poser Pro 11/Photoshop/Postworkshop 3
Believable3D ( ) posted Sun, 12 January 2014 at 3:56 PM
Nevermind. In this case, I had grown the hair right on the scalp, and it turns out I can use the face texture mapping.
______________
aRtBee ( ) posted Tue, 14 January 2014 at 8:18 AM
you mean this: http://www.book.artbeeweb.nl/?p=452 ? It uses the head map indeed.
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
Believable3D ( ) posted Tue, 14 January 2014 at 10:15 AM
Thanks. Do you find that transparency doesn't work in Preview? it's not for me, although when I render it does indeed work. I think that used to work, although I haven't compared to other stuff that uses transparency... I do know that something really went wonky after the Win8.1 update.
______________
FVerbaas ( ) posted Sun, 19 January 2014 at 10:44 AM
Forum Coordinator
Quote - Thanks. Do you find that transparency doesn't work in Preview? it's not for me, although when I render it does indeed work. I think that used to work, although I haven't compared to other stuff that uses transparency... I do know that something really went wonky after the Win8.1 update.
It may have to do with the settings/capacity of your video card. I have a very low-grade system and I see transparancy sometimes represented in preview and sometimes not. Some apps mess with the settings, and I have the impression the video adaptor sometimes makes is own choices on priorities.
