Sat, Jan 11, 7:20 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 11 12:18 am)
Subject: SR 4 issue
mr_phoenyxx ( ) posted Fri, 15 August 2014 at 2:06 PM · edited Mon, 06 January 2025 at 2:58 PM
I've already submitted a ticket to Smith Micro about this, but I wanted to know if anybody else has experienced this:
Poser Pro 2014 SR 4 was released on August 12. I downloaded it last night (Aug 14). The download link provided via email for the Poser Pro 2014 install file was actually a Zip file with two files inside: a Poser Pro install and a Queue Manager install. There is a separate URL provided in the email for downloading the Queue Manager install file. When I downloaded the separate file though, it was SR 3.1 for Queue Manager and not SR 4.
I basically ignored that oddity though, and installed the Poser Pro 2014 SR 4 update. The update went very smooth and my Poser Pro 2014 is now version 10.0.4.27796. I then used the Queue Manager file from the ZIP (not the SR 3.1 file I downloaded separately) to upgrade a separate computer's Queue Manager, and it is also now version 10.0.4.27796 of Queue Manager.
However, when I check the version of Queue Manager on the same machine that is running Poser (the one that I ran the Poser update for), it is the SR 3.1 version of Queue Manager and not the SR 4 version.
So the Poser Pro 2014 SR 4 update appears to not be updating Queue Manager on the local machine.
And now I'm not sure just how to get the proper version of Queue Manager running on all machines as you are not supposed to use the separate Queue Manager install on a machine that already has Poser installed.
Teyon ( ) posted Fri, 15 August 2014 at 2:47 PM
I believe there's a separate updater for Que Manager.  Did you try installing the one that came with the zip on that same computer instead of on the other machine?
pumeco ( ) posted Fri, 15 August 2014 at 2:49 PM
I didn't even know it was released, is there a link where the fixes/changes are listed?
mr_phoenyxx ( ) posted Fri, 15 August 2014 at 2:57 PM
Quote - I believe there's a separate updater for Que Manager.  Did you try installing the one that came with the zip on that same computer instead of on the other machine?
You aren't supposed to use the separate Queue Manager updater to update the system that has Poser installed on it though. So no, I haven't tried that yet. I thought I'd wait to see what SmithMicro said.
Pumeco -
http://poser.smithmicro.com/pro2014-updates.html
pumeco ( ) posted Fri, 15 August 2014 at 3:10 PM
Cheers mr_phoenyxx!
mr_phoenyxx ( ) posted Fri, 15 August 2014 at 3:45 PM
So SmithMicro is telling me that if I have a separate Queue Manager folder, which I do, then that isn't right.
I don't recall having ever run the Queue Manager install separately on my Poser computer. I am pretty sure Poser's install created that separate folder.
We'll see what they say though.
vilters ( ) posted Fri, 15 August 2014 at 4:09 PM
The Queue Manager needs to be installed ONLY on the slave machines.
If you have no slave machines, you do not need that QM  installer.
Believable3D ( ) posted Fri, 15 August 2014 at 5:08 PM
Odd. I wasn't alerted of an update, unless it went into a junk folder. Poser Pro 2014 didn't give an alert either, but I'm not sure if it would.
______________
Hardware: AMD Ryzen 9 3900X/MSI MAG570 Tomahawk X570/Zotac Geforce GTX 1650 Super 4GB/32GB OLOy RAM
Software: Windows 10 Professional/Poser Pro 11/Photoshop/Postworkshop 3
Teyon ( ) posted Fri, 15 August 2014 at 5:27 PM
Well don't let us confuse you (especially me, I don't use Que Manager). Send a support ticket to Smith Micro Tech Support.
arrow1 ( ) posted Fri, 15 August 2014 at 6:57 PM
I put my Poser Game serial numbers in and it would not accept these numbers.However when I put my Poser Pro 2014 numbers in I was able to download. Before I install the SR4 update I am wondering what affect it will have on Poser Game? Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Believable3D ( ) posted Fri, 15 August 2014 at 6:59 PM
I suspect Poser Game already has these enhancements/fixes, given the timing....
______________
seachnasaigh ( ) posted Fri, 15 August 2014 at 7:10 PM · edited Fri, 15 August 2014 at 7:24 PM
     Unlike Teyon, I use Queue Manager.  A lot.  :laugh:  On the master machine with Poser & Queue, you only run the Poser Pro installer;  that installer contains its own Queue.
     On network render drone machines which have only Queue installed, you run the Queue installer.
     On a master workstation, Poser Pro and Queue executables will both be in the Poser Pro 2014 folder.  On your render drones, Queue exe will be in the Queue Manager folder.  Within C:>Program files>Smith Micro, you should not have both a Poser Pro 2014 and a Queue Manager folder.  This would result if you ran both the Poser Pro installer and the Queue installer on the same machine.  That would mean you have Queue executables in both of those folders.  I can imagine there would be software confusion from that.
wimvdb ( ) posted Fri, 15 August 2014 at 9:12 PM
Quote - I put my Poser Game serial numbers in and it would not accept these numbers.However when I put my Poser Pro 2014 numbers in I was able to download. Before I install the SR4 update I am wondering what affect it will have on Poser Game? Cheers
If you have installed the Game Dev version, you already have SR4 in it
arrow1 ( ) posted Fri, 15 August 2014 at 9:28 PM
Many thanks for your replies. Cheers
mr_phoenyxx ( ) posted Sat, 16 August 2014 at 6:39 AM
Quote -      Unlike Teyon, I use Queue Manager.  A lot.  :laugh:  On the master machine with Poser & Queue, you only run the Poser Pro installer;  that installer contains its own Queue.
Yes, I know. :)
I do not recall having ever run the Queue Manager install separately on my main machine - the one that runs Poser. Obviously I have at some point though, as there was a separate Queue Manager install which was the issue. Uninstalling it and running the correct EXE file from the Poser folder resolved the issue.
Interesting though that my Queue Manager has been updating properly prior to this...
Anyway, No issue with SR 4 - just an isue with me. :)
