Fri, Oct 4, 12:21 PM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 04 8:39 am)
Subject: Help with Python Script needed?
MikeMoss ( ) posted Mon, 06 April 2015 at 3:04 PM · edited Wed, 04 September 2024 at 2:57 PM
Hi
I'm pretty sure I had this installed a long time ago, but I'm getting old and my memory isn't what it once was.
I'm trying to install the Ockham's Naturalizer6 script in Poser Pro 2014.
I have my unzipped folder with these files in it....
Naturalizer Folder/
Naturalizer.py
NaturalizerLittleOne.py
NaturalizerVic4.py
And the NaturalizerRead.txt file.
I tried just dropping the folder into the Runtime/Python/PoserScripts folder, but that doesn't make it show up in Poser.
It's been so long since I've done this that I don't have a clue what I'm supposed to do to activate this.
How do I make this work?
Thanks for the help, I ran a search but I didn't find any explicit instructions on how to install a Python Script in Poser.
Mike
If you shoot a mime, do you need a silencer?
MikeMoss ( ) posted Mon, 06 April 2015 at 3:37 PM
Hi again.
Well I remembered how to run it, but not how to add it to the Python menu, or use it.
I opened it and tried to apply it to a character.
The character's attributes display on the right, and there are sliders on the left.
I'm applying it to Jessi.
I left everything set to default and hit go, it takes a few seconds and I can see the key frames being added to the Animation Palette.
However, I don't see any movement when I play the animation, or when I go to specific key frames.
Am I supposed to do something else?
Mike
WandW ( ) posted Mon, 06 April 2015 at 4:44 PM
You put it in the right place.  Did you restart Poser after putting it there?  It won't show up until after restarting.
MikeMoss ( ) posted Tue, 07 April 2015 at 2:08 PM
Hi
I did restart it and I can run it from File/Python Script.
I seem to remember that there was a process for making it show up in the Python menu, but I don't remember what it was.
Mike
WandW ( ) posted Tue, 07 April 2015 at 2:28 PM
Oops; I lead you astray; If you put them in Runtime/Python/PoserScripts/ScriptsMenu of the Poser Program runtime they should appear on the Scripts Menu.  Sorry about that...
MikeMoss ( ) posted Tue, 07 April 2015 at 3:32 PM
Thanks I'll try that.
MikeMoss ( ) posted Wed, 08 April 2015 at 10:48 AM
That worked though the script doesn't work as well as I thought it did.
It does put in some blinks and breathing, but I remembered that it added subtle movements of the body and arms like a person just standing there, but not frozen.
it doesn't seem to do that, maybe I'll try and work out a stander pose animation that will quickly add some random looking movements to a character so they will look alive if you just want to add them to a scene.
