Mon, Nov 25, 7:22 PM CST
Renderosity Forums / Poser 11 / Poser Pro 11 OFFICIAL Technical
Welcome to the Poser 11 / Poser Pro 11 OFFICIAL Technical Forum
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Nov 17 7:07 pm)
banner
Welcome to the Poser Forums! Need help with these versions, advice on upgrading? Etc...you've arrived at the right place!
Looking for Poser Tutorials? Find those HERE
Subject: Advice for importing 3ds and obj and obj files?
willshetterly ( ) posted Wed, 21 September 2016 at 11:05 PM · edited Fri, 22 November 2024 at 4:16 PM
I've just begun experimenting with importing 3ds files, and the results are mixed. Birdman's 3ds car models from sharecg come in with opaque windows, and the initial size is enormous. Adjusting the size after importing is easy, of course, but I haven't figured out what to do about the opaque windows. Any suggestions?
hborre ( ) posted Thu, 22 September 2016 at 9:00 AM
If there are material groupings set for the model, you will need to go into the Material Room and modify the transparencies or replace the glass with actual glass shaders.
jura11 ( ) posted Mon, 26 September 2016 at 12:04 AM
Agree with above,you will need to replace or modify shader for windows,usually turn transparency to 1 and depends if you are want to have reflections then this can be achieved through few ways and depends if its Firefly or Superfly shader etc
Hope this helps
Thanks,Jura
willshetterly ( ) posted Mon, 26 September 2016 at 9:12 AM
hborre and jura11, thanks for the pointers. It looks like there's a problem with the way Birdman does things, because I saw another poster mention that elsewhere and when I look at the files in the material room, I can't identify the windows.
donnena ( ) posted Mon, 26 September 2016 at 8:28 PM
Birdman does not give his materials logical names. Trial and Error are your only friends here. I choose a really obnoxious and bright color (Think Hi Vis Orange) for the diffuse color and see where it shows up. Eventually, I find the windows.
Andy!
willshetterly ( ) posted Mon, 26 September 2016 at 10:29 PM
Excellent tip! I'll try it soon.
