Forum Moderators: wheatpenny Forum Coordinators: Guardian_Angel_671, Daddyo3d
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 19 2:48 pm)
(a) Can you put the studio into an other hard drive ?( put all of the Daz studio into another one)
Yes, you can install DS on another hard drive, but the second half of your question is vague. If you mean combining more than one DS version together, the answer is no. You can combine the content folders or simply link them to DS.
Poses from Vicky 1,2 to use on Vicky 7 or genesis 3? (only Genesis 3,Vicky 7 seem to work)
Poses created for different figures very rarely translate over to one another. Genesis 3 poses work with V7 because V7 is a character of G3F, no difference the figures. There are conversion plugins that can automatically do the pose conversion, but none exist for V1 or V2. Only V4 and Genesis 2.
Morphs not enough to fix body parts, Genesis 2 has a lot of them, V4, G1F, G2F lot's of adjustments, can a person transfer them? Possibly re-write them to fit G3F, V7?
Trying to force morphs to work between different models will not work, differences in mesh will prevent this from happening. However, using Dimension3D's GenX2 plugin will convert morphs between models very efficiently. I am familiar with Sickleyield's Dietrying's 182 morphs, but that plugin only adds more morph options to the figure. It is not intended to fix any existing morphs from other packages.
Probably "fix" is the wrong word to use as you are referring to morph options that were provided free and weren't made to fix anything. There are several products available to give more body options for Genesis 3, but they aren't free. I know thorne has several products for body shapes at DAZ that are made to work with Genesis 3, and the morphs you referred to can be transferred to genesis 3, but they would be based on the genesis 2 or one shape, not genesis 3.
hborre (a) Can you put the studio into an other hard drive ?( put all of the Daz studio into another one) I meant to say all the content on the same drive other then C:.
Male_M3dia I did not mean to say I wont pay for stuff,I only used thr free stuff as an example, I will check out thorne's products. Thank you all for your insite.
goofygrape posted at 4:46PM Sun, 15 January 2017 - #4295202
No i didn't imply that you wouldn't pay for stuff, only that there are things presently available and it's not only the morphs you mentioned.
thorne sells her genesis 3 morphs kits at daz
*~*Jamie*~*
"Life is just a dream on the way to death." ~The Crow: City of Angels
Hey all; (a) Can you put the studio into an other hard drive ?( put all of the Daz studio into another one) (b) poses from Vicky 1,2 to use on Vicky 7 or genesis 3? ( only Genesis 3,Vicky 7 seem to work ) (3) morphs not enough to fix body parts ,Genesis 2 has a lot of them ,V4,g1f,g2f lot's of adjustments ,can a person transfer them?Possibly re-write them to fit g3f ,v7 ? sorry for the long question process saves space possibly :) Thank's
