Tue, Nov 19, 9:29 AM CST
Renderosity Forums / Poser 11 / Poser Pro 11 OFFICIAL Technical
Welcome to the Poser 11 / Poser Pro 11 OFFICIAL Technical Forum
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Nov 17 7:07 pm)
banner
Welcome to the Poser Forums! Need help with these versions, advice on upgrading? Etc...you've arrived at the right place!
Looking for Poser Tutorials? Find those HERE
Subject: Poser 11 Pro gurus... I need help exporting an obj file
PenelopeFlynn ( ) posted Fri, 13 March 2020 at 4:26 PM · edited Tue, 19 November 2024 at 9:16 AM
I am needing to export a character in .obj to use in another 3D application. I have been successful in exporting the figure BUT not so successful with any of the materials and textures. How can I export to obj with everything intact? I am a writer, not a techie so PLEASE bear that in mind when you explain.
HartyBart ( ) posted Fri, 13 March 2020 at 7:56 PM · edited Fri, 13 March 2020 at 7:56 PM
Your .OBJ export should also have a .MTL file alongside it. Open the .MTL with Notepad, and check what the file paths to the materials are. I could be that you need to do something as simple as copying the materials out of a sub-folder, and then paste them alongside the .OBJ itself.
PenelopeFlynn ( ) posted Fri, 13 March 2020 at 10:03 PM
Thank you for the swift response. I will do just that.
PenelopeFlynn ( ) posted Sun, 15 March 2020 at 7:46 PM
PenelopeFlynn posted at 7:46PM Sun, 15 March 2020 - #4383504
This is a LOT more difficult than I thought. Is there a program than can do this conversion?
raven ( ) posted Tue, 17 March 2020 at 9:43 AM
To collect everything at once you can use an included script. This will export the.obj and associated textures into a folder of your choosing.
PenelopeFlynn ( ) posted Tue, 17 March 2020 at 1:34 PM
Thank you. I will try this!
caisson ( ) posted Tue, 17 March 2020 at 2:10 PM
Does the other application support FBX format? It has more options for import/export than obj format.
Not approved by Scarfolk Council. For more information please reread. Or visit my local shop.
PenelopeFlynn ( ) posted Tue, 17 March 2020 at 3:16 PM
Unfortunately it doesn't support FBX. That was my first thought. Thank you.
