Sun, Jan 26, 11:37 PM CST
Renderosity Forums / Bryce
Welcome to the Bryce Forum
Forum Moderators: TheBryster
Bryce F.A.Q (Last Updated: 2025 Jan 23 6:01 pm)
[Gallery]     [Tutorials]
THE PLACE FOR ALL THINGS BRYCE - GOT A PROBLEM? YOU'VE COME TO THE RIGHT PLACE
Subject: Poser figures in Bryce confusion
mercury_zap ( ) posted Thu, 27 December 2001 at 7:32 AM · edited Sun, 26 January 2025 at 11:32 PM
Hiya. I was curious about something. I read a tutorial for importing Poser figures into Bryce and one of the steps was to use the smoothing option on all of the objects. I'm talking about the smooth option in the Edit Terrain/Object button. Also, when I did it (as instructed) with the button for "Solid with Booleen rendering". It's something like that. Anyway, there's only one button to press besides Smooth and Unsmooth. O'tay, it's more of a curiousity than a problem, but I just wanted some info. So, the situation is rather simple. I had one project where I had three different Poser figures in one scene, but I added them one at a time and also used the Smooth option on one at a time. Worked just fine. Now I am working on a new scene in Bryce with two figures, but the figures are posed together so it's easier to export and import them as one object. Did that, but when I used Smooth this time (with both figures selected/grouped as one object) it made it worse and when I rendered it it had areas that looked like the Epcot Center at Disneyland. You could see more of a blocky effect than a smooth effect. I did it again with using Smooth and it looked fine. What the HECK is this? Like I said before it's just a curiousity since I can manage around it by just not using smooth. =P Thanks in advance.
mercury_zap ( ) posted Thu, 27 December 2001 at 7:36 AM
Blagh! I meant to say "I did it again WITHOUT using Smooth and it looked fine" in near the end. Hey, lack of sleep! :)
joke ( ) posted Fri, 28 December 2001 at 7:06 AM
If you import Poser figures as DXF or 3DS they will need smoothing. Use OBJ format instead when exporting from Poser to Bryce. ------------ Susanna: Poser Animations to Bryce 4/5 www.datamike.com/susu.htm
Phantast ( ) posted Sun, 30 December 2001 at 8:30 AM
Right - with obj format smoothing is not necessary.
