Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:11 am)
Are you doing this in the sketch style window or just the display? The hair was post production? It looks great! I wish the cartoon settings would account for a texture map. I have textured fish that I want rendered for a flash animation but I can't get their textures to render in flash..any ideas?
Never Give Up!
Render your fish with texture then take it into paint shop pro, If you reduce the colors of the image to 16 colors you should get a cartoon fish. Im still experimenting with body hair, Im not too happy with the line effect I used, What I might do is print out a sample of the image and then draw the body hair on then reduce the color to black and white and paste it on to the image using an alpha channel. Here is a trick, get your characters color correct the way you want it, In cartoon lines mode in poser, instead of rendering hit antialias it is right under render. This will sharpen your cartoon character. I got the idea for the cartoon style from looking at Barney rubble from the flintstones.
It looks great! I have seen some impressive cartoon renders using the sketch style render. I want to render cartoon animation for flash from poser and still I don't see a way to do it with textures on unless I export a quicktime movie and import it into Flash as a quicktime...keeping the colors down is important, 16 is a good number, even less. maybe you can find a prop to use for hair that will look symbolic enough... a rug for the thug's chest or something.
Never Give Up!
