Bryce F.A.Q (Last Updated: 2025 Feb 17 1:22 pm)
to a newbie from a newbie, you can import quite a few different type of models, open bryce and click on file then import object,( you need to know where your model is saved) select the model click open and away you go. some models will have there own textures and will load with the model, some will not and you will have to apply your own.try the free stuff page on this web site loads of stuff there. thre.http://www.3dlinks.com/tutorials_bryce.cfm (loads of tutorials here and some model) http://www.geowproctor.simplenet.com/labmesh.htm (for space ships)http://www.stewstras.net/baument/archives.htm (for all sorts) i hope this helps...
There are 2 ways to import into Bryce, one involves importing foreign meshes ( obj, 3DS, dfx, wrl, ect..) These are imported using the File/import object command. The other way to import involves importing local files obp ( Bryce's file type ) They are imported by opening the object library on the create palette. And using the import option at the bottom of the library. More than likely the objects on the Bryce disk are local obp objects and need to be imported through the object library.
Total new user to Bryce 5 and though I seem to have got my head around the basics of terrain and materials etc. The use of objects and especially importing new objects to use is really confusing me. I have tried to import objects from the content disc supplied with Bryce 5 - Architecture etc. but I presume these are pict objects?? Where can I get some good pre made boolean objects and how do I import them??? sorry if this is a stupid question!!!! Lindans
Oh, let the sun beat down upon my face. I am a traveler of both time and space ....Kashmir, Led Zeppelin
