Sun, Feb 16, 2:54 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 11:01 am)
Subject: Help! can't get Hair Fixed!
Netherworks ( ) posted Sat, 23 March 2002 at 9:53 PM ยท edited Mon, 10 February 2025 at 4:36 PM
I've created a hair prop in cinema4d and when I apply the texture map, there are square discolorations in the texture map. It's not the map and I expect it's a problem with the normals. So, can it be fixed or is it hopeless?
ElectricAardvark ( ) posted Sun, 24 March 2002 at 12:18 AM
If you saved it as an obj file, open the obj in UVMapper and have a look. I'm guessing your UV's didn't translate correctly
Netherworks ( ) posted Sun, 24 March 2002 at 12:33 AM
hmm... I did load it into UVMapper to remap it. Perhaps I can try that again.
SWAM ( ) posted Sun, 24 March 2002 at 2:28 AM
you have to import it in UVMapper, then correct the UV and save the model. Use this model to import in poser. This should help you, had this problem too
Netherworks ( ) posted Sun, 24 March 2002 at 3:06 AM
Ok, It worked by mapping it cylindrically instead of planar... Sheesh!
