Sat, Feb 15, 5:12 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Subject: GlassBlock?
JeffH ( ) posted Mon, 07 February 2000 at 9:24 PM ยท edited Sat, 15 February 2025 at 4:33 AM
I was fooling around in Nendo and made a GlassBlock. It's only one, but as you can see easily stacked into windows and walls. Each block is about a 10K Poser prop file. Do you think this would be useful? Would it be too much of a pain to build with this? -JH.
Sprout ( ) posted Mon, 07 February 2000 at 10:05 PM
Jeff , Those would be great for bathroom scenes, do they look good clear with a touch of the rainbow effect, and 10 k is not bad, we can always parent multiple blocks if we were to desire a quick way to build. Great Blocks!! Sprout
JeffH ( ) posted Mon, 07 February 2000 at 10:15 PM
I haven't tried to render them without colors in the transparency. Would the rainbow effect be done with the lights? -JH.
Sprout ( ) posted Tue, 08 February 2000 at 12:54 AM
Not sure Jeff, I am not good at lights in Poser. :O) Sprout
KateTheShrew ( ) posted Tue, 08 February 2000 at 1:17 AM
If they will take a texture you could use a textured glass bump and fiddle with the transparency settings to get that look of 50's style glass blocks that were so prominent in the building styles. Just a thought. Kate
JeffH ( ) posted Tue, 08 February 2000 at 9:34 AM
I left out UVs to make the file size smaller. I'll experiment and see how much larger it would make the file. I was really trying to create a style of Block that doesn't exist ;-) -JH.
bloodsong ( ) posted Tue, 08 February 2000 at 1:22 PM
heya; what do you need uvs for? i mean, wouldnt you just map a square tile onto it, and that would do it? (or do you have to make it box-mapped at the very least for it to work well?)
JeffH ( ) posted Tue, 08 February 2000 at 6:51 PM
I'm not sure you can map anything to a model with no UVs...
Nance ( ) posted Tue, 08 February 2000 at 6:53 PM
Yes, they look useful, at least I would like to play with them. Are they actually translucent?
JeffH ( ) posted Tue, 08 February 2000 at 6:56 PM
Yes, I used a bit of transparency and falloff in Poser.
