Fri, Nov 22, 11:03 PM CST
Subject: custom character
grayhuze ( ) posted Thu, 10 February 2000 at 6:39 PM ยท edited Mon, 18 November 2024 at 11:01 PM
I have taken a mesh a named all the parts correctly in Raydream 5.5. Exported this correctly, so that I have a single mesh with named parts. Phi builder and UVmapper both read this character correctly. However, the hip abdomen and chest do not show up after using the PHI file. Does anybody have a clue why? I even tried just importing the hip chest and abdomen as a new object, and had the same problem. Help pleas!! gray
PhilC ( ) posted Thu, 10 February 2000 at 6:50 PM
Can you import the whole figure.obj into Poser? If it appears with no mid section, render the scene. Does it appear now?
grayhuze ( ) posted Thu, 10 February 2000 at 7:25 PM
yes, I can import into poser and see the entire object and it renders fine. Just can't pose it. The Phi file creates a perfect character just without mid section.
PhilC ( ) posted Thu, 10 February 2000 at 7:58 PM
Body part name error? upper/lower case annomoly? Parts set to hidden in hierarchy window? If I could see the files I may be able to work it out. pcooke@mis.net
grayhuze ( ) posted Thu, 10 February 2000 at 11:18 PM
Hey, that would be great, I will send them to you tomorrow from work. I really appreciate that. I will However, try the case sensitivity thing and check invisiblity. Ill let you know thanks again gray
