Wed, Nov 27, 12:35 AM CST
Renderosity Forums / Poser Technical
Welcome to the Poser Technical Forum
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Welcome to the Poser Technical Forum.
Where computer nerds can Pull out their slide rules and not get laughed at. Pocket protectors are not required. ;-)
This is the place you come to ask questions and share new ideas about using the internal file structure of Poser to push the program past it's normal limits.
New users are encouraged to read the FAQ sections here and on the Poser forum before asking questions.
Subject: deformers ?
apache3d ( ) posted Sun, 20 February 2000 at 5:35 PM · edited Fri, 09 August 2024 at 11:53 AM
Attached Link: http://apache3d.ifrance.com
hi anybody can explain me why when i import a head in obj poser say "no same number of point" and i can change the head but i need to use it thanks
Kevin ( ) posted Thu, 24 February 2000 at 7:32 AM
You are trying to make a morph target? Don't export from poser. It will not work right. Import from the geometries folder and toss the body parts you don't need. When you make a morp target you cannot add or remove any vertices. You can only shift them around. In addtion the package you use must not change the order of the vertices.
matu ( ) posted Tue, 29 February 2000 at 7:38 AM
Thank you It works now!
