Wed, Nov 20, 1:28 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 18 10:25 pm)
Subject: help! - never succeed creating a smart prop ...
jenay ( ) posted Sun, 11 August 2002 at 4:51 AM · edited Mon, 05 August 2024 at 3:35 AM
is there a trick not described in the manual?? whatever i try - i never get the smartprop dialog when saving a prop into the library palette. here is what i do: i use the prop (an selfmade ankle ring), scale it to fit, move it, choose as parent the right shin and save it to the library palette - in the next dialog i only choose the ring to save. that's it. the next time i load the ring it appears at the exact postion where i once saved it. it doesn't care about poses or parents at all. i tried the procedure with IK on and IK off - no difference. i am crazy. i think it could be a bug in the german poser version ...? or maybe i am too dull ... if someone knows ... thanks joekurz (aka jenay)
thip ( ) posted Sun, 11 August 2002 at 5:04 AM
You might have omitted to set the prop's parent to the desired body part before saving the prop. In the above example, the ball is positioned & selected. Then choose Object - Change Parent - mark the desired body part (and tick "Inherit Bends Of Parent" if you want that effect). Then save. If Poser asks you if you want to save as a smart prop, you've succeeded in parenting the prop.
jenay ( ) posted Sun, 11 August 2002 at 5:49 AM
hi thanks - i retried again - like described - doesn't work ... i used the ball - no result
PheonixRising ( ) posted Sun, 11 August 2002 at 6:10 AM
The only thing I can think of is to double check that it is going into the props library. The key dialog you are looking for is asking you to save as a smart prop. If that isn't appearing after the prop has been parented then something is not right for sure. Try rebooting and try again. Anton anton@daz3d.com
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
"Conviction without truth is denial; Denial in the face of truth is concealment."
NEW The Poser FaceInterMixer
PheonixRising ( ) posted Sun, 11 August 2002 at 6:12 AM
try parenting it to a zeroed figure. Perhaps if the figure is posed it is causing a conflict in location.
Little_Dragon ( ) posted Sun, 11 August 2002 at 6:54 AM
I think I know what's happening. When you click the plus-sign to save the prop to the library palette, you get a dialog called "Set Name". Do not click the "Select Subset" button. Just give the prop a name, and click OK.
PilotHigh ( ) posted Sun, 11 August 2002 at 10:24 AM
I can't seem to do it either. Load prop, move to location, set parent, save to PROPS library - no smart prop option!
Stormrage ( ) posted Sun, 11 August 2002 at 12:43 PM
Stupid question here but do you have the patch on poser? If not that might be the cause
Jaager ( ) posted Sun, 11 August 2002 at 3:21 PM
Sometimes it works for me and sometimes no. There is a way to make sure it happens, if it can happen Near the top the file, you will see this: includeInDepthCue 1 parent UNIVERSE channels If you edit it to this: includeInDepthCue 1 smartparent rFoot:1 channels with rFoot:1 being whichever group you want as the parent. Often, a simple text edit is faster than banging your head against a wall.
jenay ( ) posted Mon, 12 August 2002 at 2:52 AM
thanks - i'll try again ... (yes i have poser 4.03) :) joe
jenay ( ) posted Fri, 16 August 2002 at 8:00 PM
Attached Link: http://www.joes3dfantasyworlds.com/down/accessories/accessories.htm
hi there - just succeeded with my smartprop porblem :) :) Little_Dragon had the solution: **When you click the plus-sign to save the prop to the library palette, you get a dialog called "Set Name". Do not click the "Select Subset" button. Just give the prop a name, and click OK. ** it is not stated in the manual at all ... i posted my ankle rings in the freestuff section - as a small "thank you". joekurz (aka jenay) :)
