Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
Great stuff you know you map and fix thos animated bone in cinema4dxl to an imported poser mesh and have a fully rigged poser character in cinem4DXl format. ive done twice in the past. Also Lifeforms will export a BVH file to a set of animated lightwave bones. a process that i will be using now that i am using lightwave for all my character work
Just import any BVH ( Poser-compaible or not ). Create meshes to match those bones, set Vertex Weight, Assign bones to meshes, I used to do what you said, but in my way, it takes less than 10 mins to complete one ( or just 5 mins ) in my workflow like these. Then rendered. Sure I can use Poser OBJ instead, different workflow. Indeed, LFS exported LW's bones. I created all those LFS's mocap for Poser to use, in BVH sure.
