Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 17 9:52 am)
magrindell, just a couple of general suggestions.
If you are having trouble manipulating the lights, try parenting your spotlight to an invisible prop and use PointAt on the light with the invisible prop as the target.
Adjusting this invisible target prop keeps things a little less confusing and avoids the "it pointed always to her neck, not to the head" problems.
Scaling the prop moves the light closer or farther without changing the vector to the target, which, as it sounds like you've discovered, is difficult to do just using the translation dials on the light itself.
Also, consider approaching the whole problem from the mindset of "where do I want shadows to fall" rather than "where do I want the light to hit." The former will better suggest the position of the light sources.
...and very cool eyes in no.5 jobcontrol
Hi there, Well What I need Help With is a Lighting set i want to have everything looking like a basic mid global lighting a bit shadowy and a light focusd on the eyes no Higher then the bottom of the eyebrows and no wider then the outer corners of the eyes lighter then the rest or the lights kinda like you see in the movies or tv giving that vixen look to the eyes kinda a sultry look over her eyes PLEASE someone help i have tryed makeing a spot light useing point at twards the face positioned it directly in front of the face and i have goofed with the settings a little and cant find out how to make the light do what i want i even made sure it was on spot light instead of infanite please can one of you POSER GURU'S help one of your Biggest followers
