Vue F.A.Q (Last Updated: 2024 Oct 24 1:32 pm)
Hi Hardwick, DPI refers to "dots per inch" which is only applicable on the printing end of things. On the screen, resolution is measured by pixels. To make a long story short, to be able to print with a higher DPI, you need to render with more pixels...in other words, render LARGE. In the case of a poster, render ENORMOUS! You may need to experiment with a minimal rendering to determine the best size, but think in terms of 4-digits for the pixels, for instance, start experimenting somewhere around 1500 or 1600 pixels in width. Check your printer manual for additional info that may apply for your particular printer. :) Varian -- Treasures d'Esprit http://www.varian.net/dreamview/dreamtools/vue/
Attached Link: http://hardwicks.freewebsites.com
Having a big problem im going to print some pics on a poster and the problem is that the dpi on the pics are to low to make a big poster so now im woundering if anybody knows how to get higher resolution on the pics so i can print them
