Thu, Feb 20, 5:13 AM CST
Subject: does anybody know how to get a higher dpi on the pics
Hardwick ( ) posted Thu, 20 April 2000 at 4:48 PM ยท edited Mon, 17 February 2025 at 3:18 PM
Attached Link: http://hardwicks.freewebsites.com
Having a big problem im going to print some pics on a poster and the problem is that the dpi on the pics are to low to make a big poster so now im woundering if anybody knows how to get higher resolution on the pics so i can print them
Varian ( ) posted Fri, 21 April 2000 at 2:17 AM
Hi Hardwick, DPI refers to "dots per inch" which is only applicable on the printing end of things. On the screen, resolution is measured by pixels. To make a long story short, to be able to print with a higher DPI, you need to render with more pixels...in other words, render LARGE. In the case of a poster, render ENORMOUS! You may need to experiment with a minimal rendering to determine the best size, but think in terms of 4-digits for the pixels, for instance, start experimenting somewhere around 1500 or 1600 pixels in width. Check your printer manual for additional info that may apply for your particular printer. :) Varian -- Treasures d'Esprit http://www.varian.net/dreamview/dreamtools/vue/
jarm ( ) posted Fri, 21 April 2000 at 5:28 PM
I do a lot of large format printing for my firm, usually we use A1-A0 paper. Generally to get a good full-page image at these page sizes you need at least 2500xXXXX (ratio) images to get a clear image. Basically leave your computer on over night :-)
Hardwick ( ) posted Sat, 22 April 2000 at 7:58 AM
thanx for the tips i will to rendering the pics much larger
