Forum Moderators: RedPhantom
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=301016&Start=1&Sectionid=1&WhatsNew=Yes
Final Render is in Poser Gallery Thanks again Marque for pointing me in the right direction.Attached Link: http://www.thenetherworks.com/Mesh/Victoria3to2UVfix.zip
Okay, you twisted my arm... I worked up a .uvs file that fixes the coordinates of the right nipple and one of the eyewhites in the UVs provided by DAZ for Victoria 3 to take Victoria 2 texture maps. This is not for the Victoria 3 to Victoria 2 that uses the V2 body shape - it's for the uvs that are a freebie DL at DAZ. Just wanted to make that clear, ya know how some people are. ;).
I would fix it myself, but lack the know how. I tried switching to "View Model" in UVMApper Pro. But, it won't show at all after
i apply the new UVS file?? So, i can't see where those "Loose" vertices go!
Anyhow, hope you have better luck with it!
Marco
I rendered a Picture I named Bathed in Blue in Poser 5 using a simple background, Michael 2 with standard textures and Vicki 3 using her Hi-Res textures - all from Daz. Lights were customised by me to fit the mood I wanted. I chose All white and even checked the materials for the body and face and nipples. However, the result showed a circle around the nipple. Is this supposed to happen? Is it the lights? Or a Poser 5 / V3 / Hi-Res problem? I am using Win XP on a PIV 1.6GHz computer with 512MBRAM.
