hmmm. I did it exactly the way lululee did and it worked fine. I intentionally did it that way to by pass the interlock system.(which the SR2 patch got rid of) All it asked me for was my serial number and that was it. Strange Good luck tom
“The fact that no one understands you…Doesn’t make you an artist.”
Don't try the serial number before the patch if you want to bypass the security system. Not sure if anyone is back in CL today-- they were supposed to be taking a vacation. I just installed afraid that would happen to me-- I was lucky for a change. Did P5 install, reboot, installed figures, reboot, install SR2_1 reboot launch and use serial number. Worked. So does P5 apparently.:)) Emily
:shake head: I've had so many serial numbers with l's and/or 1's and O's and/or 0's that I really don't like any number or password system which requires that you mix letters and numbers. I understand why they have to do it and it may explain why so many forumites have names which are impossible to type on the first try (I'm dyslexic, and I don't touch-type), but it usually does mean trying again with variations. Glad that you figured it out, and it was so easy to solve. Carolly
I just got Poser 5 for xmas. I installed Poser5, rebooted my computer, then installed the 2 patches. I installed Poser5SR1figures first and then Poser5-SR-2_1. Then I tried to launch the software. I have tried at least 5 times to get it to take the serial number and it won't. Any suggestions? Thanks in advance.
