Fri, Feb 14, 1:18 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:49 pm)
Subject: Ok, why does this happen?: (warning newbie question ;) )
Darkdemon ( ) posted Thu, 02 January 2003 at 6:49 AM ยท edited Thu, 13 February 2025 at 10:10 PM
I've tried to apply the Pale Victoria texture images to Victoria 3, by selecting the head in the Material Room, selecting the node next to Diffuse Color and making a new 2d-texture Image_Map, then importing the whole image. The image I get is the one I posted here. What am I doing wrong? And please, Im a newbie at this ;)
Darkdemon ( ) posted Thu, 02 January 2003 at 6:52 AM
If the above pic was unclear, here's another one:
Dave-So ( ) posted Thu, 02 January 2003 at 7:46 AM
Attached Link: http://arcana.daz3d.com/tutorials/co/co02/01.html
is the pale victoria for V3???? the way you describe making a new 2d-texture...did you make the texture yourself? The mapping is incorrect...or not mapped for the figure.... Also, there are head textures or body textures. You must use a V3 head texture on V3 head...V3 body texture on V3 body.... If this is a texture for a different figure, it will not work until other things are done.... There is quite a bit more to the whole deal, but lets start here.... you may want to check out this tutorial http://arcana.daz3d.com/tutorials/co/co02/01.html
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
tasquah ( ) posted Thu, 02 January 2003 at 8:08 AM
On your second photo you can make out a eye and lips off center on the head. Thats about the same place a V2 texture would fall so i am guessing your trying to skin v3 with v2. Is this the regular v3 or the altered UV vickie 3
Darkdemon ( ) posted Thu, 02 January 2003 at 8:27 AM
Ah, ok thnx for the feedback, I d/led the texture from FreeStuff and I didn't know you couldn't use it with the V3. So if I downloaded a tex. map for V3 my above method would be correct? cause it just wraps the whole picture around her face and doesn't place the head picture on her head etc. Oh well, guess I'll read some tuts then :P
tasquah ( ) posted Thu, 02 January 2003 at 8:58 AM
Well you can use that texture with V3 you just used the wrong V3 is all . Use the one that have a differsnt UV mapping on them for vickie 2 textures.
Dave-So ( ) posted Thu, 02 January 2003 at 5:43 PM
yep...use v3 to v2 figure, then that text will work.... otherwise, V3 textures will work for v3 the way you applied them.... Just to confuse the heck out of you, there is another way to make the v2 textures work on the v3 model....check the DAZ site for the instructions...or i think its included in the v3 readme file....I haven't tried it, but several here have---it involves settting up new uv parameter using uvmapper or another uvmapping program....
