Mon, Feb 17, 12:25 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
Subject: Oh I'm baffled..............
mikebruin ( ) posted Mon, 06 January 2003 at 8:59 AM · edited Wed, 01 January 2025 at 2:49 PM
I'd put a serious amount of cash on the fact this is a unique problem, so I thought I'd post these tests here so that everyone can stand in awe of the cutting edge humour. Perhaps my paying the going rate is not good enough when I have potentially so much more to offer. Here it is then, the comedic genius of the Firefly balooning objects.........
mikebruin ( ) posted Mon, 06 January 2003 at 9:01 AM
Poser 4 render,
Firefly,
Dave-So ( ) posted Mon, 06 January 2003 at 9:11 AM
I don't see much difference, or any
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
Dave-So ( ) posted Mon, 06 January 2003 at 9:12 AM
ah...the background part....try turning off smooth polygons
Kelderek ( ) posted Mon, 06 January 2003 at 10:07 AM
Polygon smoothing is turned off in the render settings. You can also turn off polygon smoothing for individual objects as well (In the object properties). This did not work in the first release of Poser 5, but hopefully they have fixed it with the service packs. (Haven't tested it myself)
vilters ( ) posted Mon, 06 January 2003 at 10:36 AM
Do you have a displacement map? That could couse it. Tony
Crescent ( ) posted Mon, 06 January 2003 at 10:42 AM
Sorry, it's a known "feature" and I've seen much worse than a wall inhale and suck up a few objects. ;-) It's the polygon smoothing effect. I always disable it as it screws up a lot of objects. I'm impressed that it didn't do more damage in your scene. Cheers!
Little_Dragon ( ) posted Mon, 06 January 2003 at 7:35 PM
Yes, Kelderek, it's been fixed in the latest service releases. I usually leave it disabled also. But I'll admit that it does a good job of smoothing out those old, low-poly, angular figures. Try it on the sphere prop; you can really see the difference.
mikebruin ( ) posted Tue, 07 January 2003 at 7:35 AM
Thanks and sorry about the sarcasm. I'm sure you all know what it's like. Just when everythings up and running smoothly........... I salute the patience those who managed to figure out what was causing this without writing it off as a bug like I did. Thanks again Mike
