Sat, Feb 1, 12:51 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 12:20 pm)
Subject: DAZ's Tailor do you have it and does it work well?
elektra ( ) posted Fri, 10 January 2003 at 6:12 AM · edited Sat, 01 February 2025 at 12:49 PM
I've been considering whether or not to purchase this because sometimes after toning up a character, the clothing needs to be tweeked. How well does that tool work? Does any know if it works for V3? Thanks!
FyreSpiryt ( ) posted Fri, 10 January 2003 at 6:20 AM
For me, it's had good results on all but one outfit. I consider it indispensible because I make a number of custom characters. I know the comments in the V3 file confuse Tailor, but I think you can get around that by saving her again from Poser, which strips those out.
EnglishBob ( ) posted Fri, 10 January 2003 at 6:40 AM
I don't have Vicki 3 though. I found with some clothes - I think it's ones that don't have a hip part, like shirts and blouses - that the Tailor-ised clothing would come in high in the air over the figure's head. That can be fixed by using Morph Manager to manually transfer the Tailor morphs back to the original CR2. In summary: it's not perfect, but it's waay better than doing everything by hand!
Fredy ( ) posted Fri, 10 January 2003 at 7:53 AM
Like Elektra I am thinking about purchasing the Tailor... Does anyone know, if there will be an updated Tailor for V3?
Marque ( ) posted Fri, 10 January 2003 at 8:03 AM
How bout this? You need to download two files I will try to find the old thread that explains how to do it. Already works with V3 for most clothes. Marque
Marque ( ) posted Fri, 10 January 2003 at 8:04 AM
Ack, sorry, that's Vickie 3 wearing Vickie 2's clothes. Off to find the thread for you. Marque
Marque ( ) posted Fri, 10 January 2003 at 8:39 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1021562
Here you go, this will help you out. Marque
FishNose ( ) posted Fri, 10 January 2003 at 9:05 AM
'Yes' and 'yes almost always'. Some things like straps and so on, it doesn't do too well. Normal clothes work just fine. :] Fish
Simderella ( ) posted Fri, 10 January 2003 at 9:40 AM
I can sort of make things fit using the tailor, and those files.. the only thing is they only look good from the from., look round the back and her legs protrude and the worst thing is her tops are all floating away from her bust... i have no clue how to fix this, and i have tried! LOL heres an example... this happens on most things :( any help would be great... -=SimderZ=-
Simderella ( ) posted Fri, 10 January 2003 at 9:41 AM
"the only thing is they only look good from the from" arghhhhhhhh... From the FRONT even....
Ghostofmacbeth ( ) posted Fri, 10 January 2003 at 10:21 AM
Don't have it because it is PC only, unfortunately
elektra ( ) posted Fri, 10 January 2003 at 10:53 AM
Thanks to all who posted and to Marque for providing the link to the other disucssion. Looks like I'll put this on my to be picked up list.
Lyrra ( ) posted Fri, 10 January 2003 at 2:28 PM
enlishbob, thank you for solving a problem of mine ... I was wondering why that thing was floating up there. Thougt it was a memory error. Lyrra
milamber42 ( ) posted Fri, 10 January 2003 at 3:11 PM
Tailor works just fine with V3. Tailor does have a problem with any CR2 saved from Poser 5. I do not know if CodeTwister is aware of the problem or not. I load the CR2 into Poser 4 and save it before I use Tailor.
kbade ( ) posted Fri, 10 January 2003 at 8:34 PM
I'm pretty sure DAZ/Codetwister is aware of the situation with P5, but I wouldn't bet on anything happening. First of all, there's the DAZ/CL tension. Second, the workaround described above is also known. Third, I seem to recall word in the forum being that Codetwister wasn't planning an update because he thought dynamic clothing (or dyn cloth based solutions) would render the Tailor obsolete...which may be true in the long run, but probably not for a while.
