Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 12:52 pm)
I don't have Vicki 3 though. I found with some clothes - I think it's ones that don't have a hip part, like shirts and blouses - that the Tailor-ised clothing would come in high in the air over the figure's head. That can be fixed by using Morph Manager to manually transfer the Tailor morphs back to the original CR2. In summary: it's not perfect, but it's waay better than doing everything by hand!
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1021562
Here you go, this will help you out. Marque"the only thing is they only look good from the from" arghhhhhhhh... From the FRONT even....
I'm pretty sure DAZ/Codetwister is aware of the situation with P5, but I wouldn't bet on anything happening. First of all, there's the DAZ/CL tension. Second, the workaround described above is also known. Third, I seem to recall word in the forum being that Codetwister wasn't planning an update because he thought dynamic clothing (or dyn cloth based solutions) would render the Tailor obsolete...which may be true in the long run, but probably not for a while.
I've been considering whether or not to purchase this because sometimes after toning up a character, the clothing needs to be tweeked. How well does that tool work? Does any know if it works for V3? Thanks!
