Sun, Feb 9, 1:17 AM CST
Subject: Light Lab Keeps turning on Use Gel--Help!
clyde236 ( ) posted Mon, 13 January 2003 at 2:02 PM · edited Sun, 02 February 2025 at 7:10 PM
Hi, Has anyone encountered this problem and do you have a solution? I set up a light for a scene. Let's say a simple spotlight. I go into the Light Lab and check ON Color: Uniform. I leave Use Gel unchecked. Everything is fine and I can continue with my scene and save as normal. BUT, when I open the saved scene, the lighting has changed! I go into Light Lab and see that Bryce has turned on USE GEL! I can uncheck it and then the lighting returns to normal. But after I save, when I reopen the document, the same thing happens. I'm using "Bryce 5.0.1 Build" (That's what is says in the INFO box) which I got from the Corel Web site (MAC version). Should I dump my preferences or something? If anyone has a clue about this, I'd really appreciate hearing from you. Thanks!
Incarnadine ( ) posted Mon, 13 January 2003 at 3:57 PM
It's a known bug. I only seem to have it happen if I set one light with a gel. I then have to change back all the others after the next save. This is something we hope will be fixed with the next version.
Enforcer ( ) posted Mon, 13 January 2003 at 9:53 PM
Try setting the offecding light material to a flat white. 100% diffuse with no other mat settings. Then go back into the light editor and turn off the gel. This has worked for me in the past.
SevenOfEleven ( ) posted Wed, 15 January 2003 at 4:13 PM
I had the same problem, thought I had to read the manual. Gels add to render time too, so you don't want them if you don't need them. Will this work for colored lighting too?
