Hi, Has anyone encountered this problem and do you have a solution? I set up a light for a scene. Let's say a simple spotlight. I go into the Light Lab and check ON Color: Uniform. I leave Use Gel unchecked. Everything is fine and I can continue with my scene and save as normal. BUT, when I open the saved scene, the lighting has changed! I go into Light Lab and see that Bryce has turned on USE GEL! I can uncheck it and then the lighting returns to normal. But after I save, when I reopen the document, the same thing happens. I'm using "Bryce 5.0.1 Build" (That's what is says in the INFO box) which I got from the Corel Web site (MAC version). Should I dump my preferences or something? If anyone has a clue about this, I'd really appreciate hearing from you. Thanks!
