Mon, Jan 13, 12:52 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: M2 Angel - Awful Soul AsHipC2 - Feb. Challenge WIP
cainbrogan ( ) posted Wed, 29 January 2003 at 9:50 PM · edited Mon, 13 January 2025 at 12:00 PM
First thing I'd like to do is some work with Awful Soul's AsHipC2 Loin. How can I remove these side pieces? I have Carrara, but would like do this domestically, as positioning this piece for M2 took me all day!
Then I'd like bring it into the Cloth Room. My goal there is to get a perfect/skin tight fit to the Loin. I have my manual right here, but would prefer to learn more quickly through an online Tut. or two. Any links on what to expect from the Room will be appreciated!
Then it's over to the Materials Room, has anyone seen any white and gold MATs for this?
cainbrogan ( ) posted Wed, 29 January 2003 at 9:59 PM
You can see why I want to learn the Cloth Room, from the huge bending space visible at some angles.
And what are those big thingers on his sides?
Dave ( ) posted Wed, 29 January 2003 at 10:48 PM
Where did you get the wings? Dave
pdxjims ( ) posted Wed, 29 January 2003 at 10:54 PM
The loin cloth is divided into a number of body parts. The two side pieces are Sinistro and Desrto. Just turn the visibility on those two parts off. As for fit, it's designed for a female shape. The only way you'll get a tight fit is to add a couple of custom morphs on the belt. This isn't too hard at all, really. Steve Shanks has a great tutorial on using Anim8or to make custom morphs. The principle would apply to Carrara too. His tuorial is at: http://interneteye3d.com/Tutorials/2000/sept/posermorph/default.asp There's some good P5 materials (free) at rDNA. Check them out. By looking at them, you should be able to get a pretty good metalic texture for it. Traveler may even have one included (I don't remember). Hope this helps.
pdxjims ( ) posted Wed, 29 January 2003 at 10:56 PM
Dave, The wings look like the Angelyna wings by Sharkey available in the MP here. They're great.
cainbrogan ( ) posted Thu, 30 January 2003 at 12:20 AM
Yes those are Sharkey's Wings! There not to shabby, huh? It's divided into at least 6-8 parts and bends around very nicely. If you get it have a look at M2 and V2 "Heaven Sent" Pose colllection, also avbailable in the Marketplace. There are also a few free texs., trans, and pose sets in the Free Stuff here and at 3DCommune!
pdxjims - Yes that helped alot thanks! The visibility will come in handy. I was thinking if the whole belt were considered a cloth, then gravity would make it fall and rest on his hips. As for the custom morphs, well, I'm a Super Newbie when it comes to modelers...I'm going to go have a look right now!
pdxjims ( ) posted Thu, 30 January 2003 at 12:24 AM
Actually, you got me to look at it and I think I'll try morphing it to fit Mike. It's actually pretty close now. I may even try to make it into a conforming figure for Mike. It's an excellent piece, like all Awful's work. Wish Awful would do stuff for Mike (hint hint).
cainbrogan ( ) posted Thu, 30 January 2003 at 12:40 AM
Hey that would be super pdxjims, thanks a million! Any idea of what kind of time frame we are working with here? I've a couple weeks to get this ready for before Febuary's Challenge deadline. I wish Awful Soul Would do some stuff for M2 also. His mgVest is my favorite top(nudge nudge)!
Mesh_Magick ( ) posted Thu, 30 January 2003 at 2:07 AM
You know I doubt spiritiual beings have genitals to cover, Because they have no need to make corporial offspring.... But he looks fantastic in the loin cloth:)
Mesh_Magick ( ) posted Thu, 30 January 2003 at 2:08 AM
Oh by the way leave the side pieces they look great.
amon_g ( ) posted Thu, 30 January 2003 at 6:27 AM
Attached Link: http://www.philc.net/tutorial4.htm
Hey Cainbrogan, Here's a link to PhilC's site, he has a tutorial on making P4 clothing work in the cloth room. I haven't had a chance to try it out yet, but I think it should help you with the loin cloth. Hey, and thanks for your suggestion on the tutorial a couple of threads down. It would be cool to have some samples of what you can do in the cloth room;) ~ amon_g ~
pdxjims ( ) posted Thu, 30 January 2003 at 10:51 AM
I've been working with the loin, but I won't have enough time with other projects to get it done for the contest for you. I do however have some advice on posing it. First, pose Mike the way you want him without the cloth. Second, add the cloth and conform to Mike. Most of it will be hidden in his body. Third, go to the body option and start resizing the cloth. Do this at the body level. Fourth, when you've got a fairly good fit sizewise, select the hip. Do not select the belt, it has to be the hip. Use the Z and Y trans and the X rotate (dials only) to position the cloth to the body. You'll probably have to go back to step 3 a couple of times for fitting.
Dave ( ) posted Thu, 30 January 2003 at 10:52 AM
Nice image
cainbrogan ( ) posted Fri, 31 January 2003 at 2:23 AM
Loin MAT WIP! How is this scheme coming? Anyone want to see an all white version? How about the belt in yellow? Getting the curves in the cloth whites to appear without being washed out or too gray has taken me all day. I think I'm pretty close though. I managed make a finer linen texture map by loading a regular cloth tex. and then changing its U and V scale to a mear fraction of the origional. This helps bring out the curves alot, but there is still a fine line between gray and washed out. Has anyone a silk or satin texture? = )
Dave ( ) posted Fri, 31 January 2003 at 7:47 AM
What texture are you using for Mike2? I kind of like it. Forgive me if you already told us. Dave
cainbrogan ( ) posted Fri, 31 January 2003 at 5:10 PM
Its the M2HeadM texture, but I spent a day or two in photohsop changing the eybrows blonde. Anyone care to compare or contrast the two colors schemes of the loin? = )
amon_g ( ) posted Fri, 31 January 2003 at 5:13 PM
The all white is okay, but I think I like the gold better. Gold and white seem to tie the sky into it (clouds and the sun). That's what I see when I see an angel. This is looking damn good! ~ brent ~
cainbrogan ( ) posted Fri, 31 January 2003 at 11:30 PM
Thanks for your input amon_g! I feel the same way, I call the all white "M2 Angel 0", M2 Angel 1, and others that succeed will definately have colorful gold trim.
I've been looking all around for an intricate set of sandals! These are from Daz3D's M2 Clothing Pak. Daz3D also has a full calf sandal, included in thier Millenium Olympians Clothing, I'll probably use on another angel. There is also a full calf sandle, that I remember having in a past library if mine, on an HD that crashed, but I ca'nt remember it's name. It was with a Barbarian or Warrior type figure, and had very thick straps, but I also think it have several morphs for at least height. Hopefully I can find it or something like it with thin straps!
Dave ( ) posted Sat, 01 February 2003 at 12:09 AM
I had a warrior sandal in the MP for awhile but I think it eventually got moved out. I can scrouge around for an image if you want. Dave
cainbrogan ( ) posted Sat, 01 February 2003 at 2:05 AM
Yes please. = )
Dave ( ) posted Sat, 01 February 2003 at 1:29 PM
Here's the best that I can come up with. Thanks, Dave
cainbrogan ( ) posted Sat, 01 February 2003 at 2:01 PM
Hey nice image! I think those are them. What was the name of you product? Do the sandles have morphs? = )
cainbrogan ( ) posted Sat, 01 February 2003 at 2:07 PM
I must ahve HAD a copy of them, because I can find my template pak , but not the sandals themselves! = )
cainbrogan ( ) posted Sat, 01 February 2003 at 8:10 PM
Here is the latest. I put gold on his soles because he'll be flying around, but I wonder what an Angel would sound like walking around..? I think he's about ready for his friend, I plan to add one more character and a bryce bkg., but I ca'nt decide if I want the other figure rendered in Bryce or Poser...
Anyhows, I have a couple technical questions! How are prop objects parented, the same way as a figure? I still need to parent his halo. And how do I change the name of a figure? His sandals are named Figure 2 and Figure 3, but this could get really confusing soon!
Dave ( ) posted Sun, 02 February 2003 at 3:44 PM
My product was called Mike's Warrior pack and is available in the marketplace(I think). If it's not let me know Thanks Dave
