Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Could the problem be due to the fact that The Bishonen figure is a morph for Michael versus a new mesh? Could The Tailor solve this problem? I was thinking of making clothing for the Bishonen figure myself, and would like to know what I might be coming up against. Thanks for the help Steve, and please DO post the result of you finding here.
Shouldn't be Ron, i may be way out here but i think the fact that hes slimmer should make setting up the Spherical zones easier, but then looking at the pics maybe not....either way it shouldn't matter i've done them for heavy mike and a younger Vicky 2 and it wasn't a problem, what is a problem (with a heavy figure) is the joints are set up for a normal mike so you do get a bit more poke through with a heavy version, but its not so bad to put you off....Taura hasn't been in touch yet, but if she does i'll let you know ASAP..Steve
I think if you scale them in poser it might mess it up more (ifact i'm sure it will :o)....i think all you need to do is adjust the shins to match up with an unstretched mike.....if it had been a normal figure you'd have been spot on coz your modeling and cutting was perfect, its just his scaled body parts that messes it up ..glad to help ;o).Steve
