Mon, Feb 10, 9:07 PM CST
Subject: Hmmm... possibly a strange request for help put please read through
Wind_Danzer ( ) posted Tue, 04 March 2003 at 9:21 PM · edited Mon, 10 February 2025 at 9:01 PM
Hi. I'm interested to use the image above in Bryce 5. How does one go about using it? Does it have to be a .jpg image or a bitmap? Can it be used as terrain? Any help is greatly appreciated!!! :)
tjohn ( ) posted Tue, 04 March 2003 at 9:53 PM
2d pic on the left, terrain on the right. I used the image you posted without alteration. To create a 2d pic, pick the "Leo" icon on the create menu, then load in your pic. For the terrain, create a terrain, and in the terrain editor increase the resolution, load in your picture via the picture menu, smooth a few times and you'll have your terrain object. I inverted the terrain and used clipping on it to get the version you see here. Hope this helps.
tjohn ( ) posted Tue, 04 March 2003 at 9:54 PM
P.S. A higher res pic would help the terrain look less bumpy.
Rayraz ( ) posted Wed, 05 March 2003 at 4:15 AM
BMP creates better bumpmaps since it doesn't create loos of detail. The bumpness in tjohn's example is because of the JPG-artefacts. A heavy edge perserving smooth in PSP might help to get rid of the JPG-artefact.
(_/)
loos = loss bumpness = bumpyness
(_/)
Erlik ( ) posted Wed, 05 March 2003 at 4:48 AM
A bigger background might also help. You know, 768x768 pic where the actual cross takes only something like 300x300 pixels.
-- erlik
nuski ( ) posted Wed, 05 March 2003 at 8:09 AM
Another possibility. . . . Process a gray image to include several levels of brightness. . . . when the 2d image is assigned to the object, each matching area will have a different amount of relief height.
Wind_Danzer ( ) posted Wed, 05 March 2003 at 11:24 AM
Wow guys, thatnks for the looks and the directions. I'll need to find a better pic or touch it up some but wow... I'm impressed with this stuff. Thanks a lot!!!! :D :D
pauljs75 ( ) posted Thu, 06 March 2003 at 12:36 PM
A slight gaussian blur done to the terrain greyscale image using a 2D program will smooth the edges and make it look better as well. Also having a higher grid (resolution) setting on the terrain editor will usually result in a more sharply defined object. You can also have fun with using a black&white or greyscale copy used on the specular and reflective layers. By doing so you can have a reflective & shiny (metallic?) material combined with a plain colored one. I did something similar to this for an emblem I made for a car. (Dunno what I did with it though, maybe I should look huh?)
Barbequed Pixels?
Wind_Danzer ( ) posted Thu, 06 March 2003 at 4:54 PM
tjohn, Ok, I've been able to get the terrain image on Bryce but I can't figure out the clipping you are talking about. I'd like to make it just the way you have it in this post. How do I go about "clipping" it? Or is clipping another type of program.
tjohn ( ) posted Thu, 06 March 2003 at 6:31 PM
Wind_Danzer: If you go into the terrain editor and click on the little icon the little red arrow is pointing to the gradient bar will appear on the right.
tjohn ( ) posted Thu, 06 March 2003 at 6:32 PM
Click on the bottom of the bracket and drag up to clip from the bottom. Click and drag the top down to clip from the top.
