Fri, Nov 29, 6:20 PM CST
Subject: Poser and fresh install of XP Pro
SophiaDeer ( ) posted Tue, 04 March 2003 at 6:26 PM · edited Tue, 26 November 2024 at 8:37 AM
Hello, I am a nervous nellie about this. I am having a professional do a fresh install of Windows XP Pro ( I have ME and it stinks) I may sound stupid but does the fresh install still keep all the folders I have on my two hardrives? I have lots of folders for Poser and then other folders with various other things in them. I am looking forward to getting rid of ME! Thank you in advance. Warm Regards, Nancy Deer With Horns (SophiaDeer)
Deer With Horns Native American Indian Site
Cybermonk ( ) posted Tue, 04 March 2003 at 6:39 PM
I just put XP on mine and had no problems with Poser. And your right about ME sucking I didn't realize how much until I got rid of it.
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
PabloS ( ) posted Tue, 04 March 2003 at 6:41 PM
Nancy, Generally, "fresh" means reformatting the hard drive which would eliminate everything you have on your drive. If that's not what you want, you ought to specify. Either way, it would be good idea to backup items you want to keep before the install. Hope that helps! Paul
SophiaDeer ( ) posted Tue, 04 March 2003 at 6:45 PM
Thanks so much! I appreciate the advice! Warm Regards, Nancy
LaurieA ( ) posted Tue, 04 March 2003 at 7:09 PM
Yeah, make a really comprehensive backup of everything you want to keep. Actually it's better to do a fresh install rather than an upgrade. Even tho the upgrade to XP is what I have, I always do a clean install. I don't want ANY vestiges of Win98SE behind to fiddle with things. I'm just paranoid I guess...LOL. Truth be told, I was really very fond of Win98SE. But I adore XP :o). Laurie
SophiaDeer ( ) posted Tue, 04 March 2003 at 8:48 PM
Thank you so much! Warm Regards, Nancy
sandoppe ( ) posted Tue, 04 March 2003 at 9:02 PM
Definitely backup what you don't want to lose. I agree with Laurie....the fresh install is the only way to go. I was like you....very uncertain about it. But I would never go back to 98SE and certainly not to ME. You will absolutely love XP Pro:)
Tamela.J. ( ) posted Tue, 04 March 2003 at 9:28 PM
Nancy
If your C drive is where the fresh install is going, make sure that anything on that hard drive gets burned to CD or moved to your other Hard Drive. Everything on the Hard Drive your putting WinXPPro on will be lost. When they do a fresh install they reformat it. Very simple process & painless unless you have forgotten to back up everything on that drive.
If your email is on that drive you may want to back this up as well along with your address book. To do that, Go to File (in Outlook Express)Export, Address Book & save it on your other drive. That will back up your Address Book, to back up your email go, Tools, Options, Maintenance, Click the tab that says Store Folder Copy & Paste that in a Notepad then close the Options out by clicking ok, Go to Start on you Run & paste that store folder into the box, then click ok, it will pop up your email, make a folder on your other hard drive that says OE Email 03 or something like that, open the folder copy & paste all your email files from the email store folder. That will save all your email. :O)
Its very easy to put back too after the new install. Or you can keep your mail on that hard drive & change the store folder in Outlook Express, which is what I do.
HTH
Big Hugz
Tamela
SophiaDeer ( ) posted Tue, 04 March 2003 at 10:31 PM
Thanks so much, Tamela!! Hugs, Nancy
Tamela.J. ( ) posted Tue, 04 March 2003 at 10:37 PM
Your welcome sweetie!! Big Hugz
RHaseltine ( ) posted Wed, 05 March 2003 at 1:27 PM
If you already have the XP CD you can run the Files and Settings Transfer Wizard from it under ME, pick what you want and put the resultant file on a CD which should enable you to restore address book, bookmarks etc. in one go (but make a standard backup too, in case it doesn't work). It worked for me with no probs., except having to specify the decimal seperator in Regional Settings before Poser would give me fractional values in parameter dials.
SophiaDeer ( ) posted Wed, 05 March 2003 at 3:21 PM
Thanks for the info! Warm Regards, Nancy
