Well, I D/L & installed the latest Vue update, but the same thing happened again - over 6 hours of just the hourglass and nothing loaded. Neither MaxMem nor RamIdle made any difference. I've tried MemTurbo previously and id had little effect, but I'll dig up another copy and try it with this. after work.
I also noted that you didn't mention any REBOOT of your system. Sorry if it was obvious that you had done so. But if not.... then it could be the result of Poser's common memory leaks.
Heheh... You're right, I did forget to mention it, but in the 2 days I did reboot approximately 23 times. I also forgot to mention I tried penguinisto's trick of Rt-Clking on Poser in XP services, and adjusting priorities several different ways and settings at several points in the process. I even tried exporting the scene as an OBJ, but-that just crashed Poser completely - closed it down & disappeared from memory without a trace. I tried several other things as well that don't come to mind, but I'd really like to get this scene rendered, so anyone else with a suggestion, please feel free to post it. I'm guessing it has to do with all the Refl maps, as I've had much larger scenes with no problems, but it was rendering fine until I added the last 3 items, and still wouldn't even after I deleted those and several others. Weird, huh? ...Thanks....
Think I found it... I finally coaxed a different error message out of PPP - "Can't find required Bump Map..." Rebooted & reloaded the full scene, checked in the Bum Map list, then did a search on each. Found where 2 of the robots loaded without error, but the required Bump Maps weren't there. (1 from FreeStuff, one from a commercial product that was refering to a folder on drive E: (my drive E: is a Smartcard slot). I went thru one of the preliminary PZ3 with WordPad and deleted all reference to bump maps, and now the scene finally renders. Working on the full PZ3 now. Don't know how the CR2's loaded without errors, but if PPP had a better system of error messaging it would have saved me 3 days of tedious trial-and-error. Thanks for all the suggestions, everybody. sigh
