Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 11:56 pm)
You can use Renamer. Get it here.
I use it for exactly that. Renaming MAT extensions. It's free, small file size and totally safe. It gives you a confirm or a preview, can be used to rename files, folders and sub-folders, change filenames to lowercase text, etc, etc.
mac
Attached Link: http://www.1-4a.com/rename/
"Rename" is the one I use. It change the extensions and the file names too. I find it very usefulMy alltime multiple file renaming utility favorite is MultiRen. A freebie from Ziff-Davis Publishing. I like it because I can select specific files, the RtClck on them to rename in any fashion I choose. I've used it in all version of Win from Win95 thru Me, but in XP since SR1, it causes sporadic SHELL32.DLL faults in Explorer when RtClckg (about one time in 45 or 50). Now I only install it for special projects and use Bulk Renamer instead for everyday stuff. If all you want to do is rename extentions, just make a plain text file with the rename command in it (as in Ren *.PZ2 *.HD2) and save it with a name like RenPZ2HD.BAT - copy the file into the folder you want to use it in, and DblClck it. A DOS window will flick into view for a second, and the command will execute. Simplest method I've come up with.
Attached Link: Bulk Rename Utility
I have used Bulk Rename Utility on many occasions in the past and found it to be powerful yet easy-to-understand utility. I have not used it for a while, so I am unsure whether it can recurse sub-folders.Attached Link: http://hp.vector.co.jp/authors/VA014830/english/FlexRena/
I use Flexible Renamer. You have the option of using regular expressions - pretty funky if you've got lots of files named in one convention and then you want to change them to something else! Takes a little while to work out all the possibilities but if it can be expressed as a rule, the program can do it!This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Is there a (free!) program that can rename many file extension at once? For example, I want to rename all of the "MAT"'s in my Pose folder (pz2) to camera folder extensions (cm2). I can do this by hand, but there is over a hundred folders with an obscene amount of files inside them. Thank you! Lhiannan
