Tue, Feb 4, 8:21 AM CST
Renderosity Forums / Fractals
Welcome to the Fractals Forum
Forum Moderators: Anim8dtoon, msansing
Fractals F.A.Q (Last Updated: 2025 Jan 21 7:59 pm)
Subject: Thumbnail size
Wojteg ( ) posted Fri, 28 February 2003 at 4:22 PM ยท edited Tue, 04 February 2025 at 7:33 AM
Hello! I have problem with 15kb limit size.My thumbnails compare to others are ones of the smallest and with some of them I have difficulty to fit in correct limit. I used Photoshop to convert files to JPG format but even at zero compresion very often is not enough. Greeetings.......Wojtek.........
Cindy5663 ( ) posted Fri, 28 February 2003 at 8:26 PM
Go and get yourself a good thumbnail program. Try looking at www.webattack.com or www.download.com or www.hotfiles.com All of these sites have freeware and shareware available. You should be able to find something that will work for you. C :)
Zbootsboy ( ) posted Fri, 28 February 2003 at 9:28 PM
I agree, I post a thumbnail res. of 200x200 and I use my Paint Shop Pro 7 and don't have a problem. It let me export in a broad band of commpression rates, let's me see the results and even gives the download time it will take. Try Cindy's advice I'm sure there are some good freebies out there.
sophielerlei ( ) posted Sun, 02 March 2003 at 3:59 PM
i got the same problem, wojtek. and i resolve it in photoshop by converting the thumbnail with the "save for web" option instead of "save as" and then jpg, like i did before. this makes a big difference in file size i never noticed before.... i can save a thumbnail now with 30% - 60% quality and the file is still small enough for a "renderosity-compatible" thumbnail :-). it seems like the "save for web" option generates a better optimized file.
KiDAcE ( ) posted Mon, 03 March 2003 at 2:19 AM
sophielerlei nailed it however there is a easy to use program from ulead.com called smart saver pro that does a lot more than optimize thumbnails. They also have paint programs and 3D programs and am quite suprised that almost nobody I know of seems to use them....they are professional grade producers and their paint prog Photo Impact also supports PS plugins but they have awesome plugins built into PhotoImpact7 too. Not to mention plugs for PS as well. Great place to shop!
MidDayCrisis ( ) posted Mon, 03 March 2003 at 4:31 AM
I agree with Kidace on the ulead products especially smart saver pro. I couldn't make digital images without this program now. It just gives you so much control over the compression of images. Money well spent and 2 thumbs up.
fayrelady ( ) posted Tue, 04 March 2003 at 4:42 PM
I use Ulead PhotoImpact primarily because its the only one I understand enough to do what I want. I looked in at the forum to see if anyone else was having this sudden onset of thumbnail size problems and I see I'm not alone, R***** must have come down hard on their rules at the same time as changing things on the site. Anyway I'm pleased a solution has already been offered.
shood ( ) posted Fri, 07 March 2003 at 7:46 AM
If Renderosity checks for the size of the thumbnail first it would be better than having to wait for the pic to upload only to be negated due to the thumb size. Does anyone know for sure which is checked first?
firefly ( ) posted Sat, 08 March 2003 at 11:01 AM
Unfortunately the way "packets of info" go across the net one can't guarantee that the thumbnail is going to be the first item to arrive and be viewed by the checking system. It pretty much has to wait until all bytes are recieved and reordered.
