Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 01 9:20 pm)
I don't know about cinema 4d or vue, but I've got one to work in Bryce, and the technique qould be the same: In bryce, you can inport textures to use as a transparency settings. Although the hair isn't (wasn't) exported with this, all I had to do was apply the transparency settings within bryce in the hair mesh, and it worked fine ...
Hi, thanks...I'm wondering - do you mean "apply 'alpha' settings"? It seems that transparency settings, in Cinema at least, would just make then more or less transparent. What I get from an export is 'solid' geometries , then I go to the poser tex files for the hair to apply the textures and the result is textured solid geometries..... I tried to apply the same hair texture as an alpha but nothing happened. I'll work on it some more because if you did it in Bryce, then possibly it can be done in C4D. Many thanks - more suggestions are very welcome! tantrikk
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=354109
My picture JoAnn feature the VR hair and it seeemd fine and that was rendered in Vue, I just imported the PPZ file from Poser, no fiddling at all.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hi, I'm not able to figure out how to get hair trans maps to work in other 3d apps - usch as Cinema 4d or Vue. Maybe I'm not even getting them out of Poser (V4 - NO pro pack) correctly. Can anyone help with this? many thanks, tantrikk
