Tue, Dec 3, 1:09 AM CST
Subject: Hmanns Magix-VR-Hair into other 3D apps?
tantrikk ( ) posted Sun, 16 March 2003 at 7:55 AM ยท edited Sun, 01 December 2024 at 11:02 PM
Hi, I'm not able to figure out how to get hair trans maps to work in other 3d apps - usch as Cinema 4d or Vue. Maybe I'm not even getting them out of Poser (V4 - NO pro pack) correctly. Can anyone help with this? many thanks, tantrikk
Adessil ( ) posted Sun, 16 March 2003 at 8:10 AM
I don't know about cinema 4d or vue, but I've got one to work in Bryce, and the technique qould be the same: In bryce, you can inport textures to use as a transparency settings. Although the hair isn't (wasn't) exported with this, all I had to do was apply the transparency settings within bryce in the hair mesh, and it worked fine ...
tantrikk ( ) posted Sun, 16 March 2003 at 8:33 AM
Hi, thanks...I'm wondering - do you mean "apply 'alpha' settings"? It seems that transparency settings, in Cinema at least, would just make then more or less transparent. What I get from an export is 'solid' geometries , then I go to the poser tex files for the hair to apply the textures and the result is textured solid geometries..... I tried to apply the same hair texture as an alpha but nothing happened. I'll work on it some more because if you did it in Bryce, then possibly it can be done in C4D. Many thanks - more suggestions are very welcome! tantrikk
farang ( ) posted Sun, 16 March 2003 at 8:36 AM
To use transmaps in Cin4D you have to reverse the maps. E.G. what is black in the map should be white and visa versa. If you have photoshop this is not hard to do. Good luck.
tantrikk ( ) posted Sun, 16 March 2003 at 8:44 AM
Hey farang, thank you.....(u n BKK?) Cinema hs an option on the materials dialog box to do judt that - reverse the map. I'll try it or else use PSP. sincere thanks. IM me if you exist doing 3D/BKK or similar. Would love to hear from someone like that. tantrikk
jarm ( ) posted Sun, 16 March 2003 at 9:33 AM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=354109
My picture JoAnn feature the VR hair and it seeemd fine and that was rendered in Vue, I just imported the PPZ file from Poser, no fiddling at all.
tantrikk ( ) posted Sun, 16 March 2003 at 9:47 AM
OK, thanks, dont know what a PPZ file is but I guess i'll find out. (nice render by the way!)
jarm ( ) posted Sun, 16 March 2003 at 9:51 AM
PPZ should be the default Poser file that you save from Poser. Vue 4 imports poser files natively so you should be able to just drop it in by going to Import object option in Vue. best wishes Jody
tantrikk ( ) posted Sun, 16 March 2003 at 10:27 AM
Ok thanks....oh yes, THAT PPZ file! .... I'm needing to get it inot Cinema first, needs an .obj. Thanks again,
tantrikk ( ) posted Sun, 16 March 2003 at 4:50 PM
Thank you all, I got it. Transmaps...I didn't know about them. Do now!
