Sun, Feb 2, 1:02 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Subject: should my undies have buttocks in them?
Taura Noxx ( ) posted Sun, 16 March 2003 at 6:33 AM Ā· edited Thu, 15 August 2024 at 4:22 PM
Just wondering about these hippy undies I made. I grouped them with just the hip cause I thought they would be too small to put some buttocks in. But they are quite low cut and they aren't conforming too well when you move the legs around as they are. Any ideas on how much should actually be included in the buttocks region? You can see in intersecting with the thigh. The top is conforming fine, just need a little advice on the undies. Thanks.
steveshanks ( ) posted Sun, 16 March 2003 at 6:45 AM
Be best putting them in coz Vicky (this is Vicky2 ?) has the buttocks cut real high like a thong, also look at the back of Vicky you'll see a large area of your panties need to be buttocks there too, if you are cutting them in your 3 app try coloring the model to use as a guide, if you can't do that a background image might help...Steve
Taura Noxx ( ) posted Sun, 16 March 2003 at 6:51 AM
how much of them should be buttocks? Like how do you do the crotch area. Or do you just divide the pants into thirds with the hip down the centre and the buttocks on either side but not in the crotch area? I mean its quite squizzy in the crotch area. Hehehe thanks for answering, sorry to add more questions. I might do a quick pic of what I mean .....
Taura Noxx ( ) posted Sun, 16 March 2003 at 6:55 AM
like this?
brycetech ( ) posted Sun, 16 March 2003 at 6:59 AM
tbt poser doesnt use lbuttock and rbuttock to conform if you are of the real need to put additional parts in, put lThigh and rThigh (poser uses those to conform) BT
Taura Noxx ( ) posted Sun, 16 March 2003 at 7:06 AM
Vic lo-res there btw
steveshanks ( ) posted Sun, 16 March 2003 at 7:11 AM
Might be better cut like that but really you need to cut it the same way as the model, so you'd be high at the sides on the front so the hip would look like a thong if you deleted the buttocks and the back needs to be almost ALL buttocks, hide the buttocks on Vicky in poser and rotate her you'll see what i mean....BT these are pants!.....Steve
steveshanks ( ) posted Sun, 16 March 2003 at 7:13 AM
If you want you can send them over and i'll cut them to show you what i mean, just not sure how long it'll take i'm off to hospital in a few minutes (nothing major ;o)..steve@poserworld.com Steve
Taura Noxx ( ) posted Sun, 16 March 2003 at 7:15 AM
that is very generous thank you email on the way and good luck with the hospital even if it isn't major ;)
PabloS ( ) posted Sun, 16 March 2003 at 7:45 AM
chohole ( ) posted Sun, 16 March 2003 at 8:34 AM
I am sorry but when I read the topic header my mind boggled. My immediate thought was that they would have to be real skimpy undies if they didn't.
The greatest part of wisdom is learning to developĀ  the ineffable genius of extracting the "neither here nor there" out of any situation...."
brycetech ( ) posted Sun, 16 March 2003 at 10:14 AM
??? be they pants or a rubber ducky... :P poser doesnt use buttocks to conform..that is it dont use them for alignment of the body parts when the model is conformed. It does use thigh. In fact, its hard coded in poser. (Kinda like where you cant put a child on a foot other than a toe..if you do, poser renames it to toe) The buttocks addition will most likely not cause any problems..so it probably doesnt really matter which you call it in this case. :) BT
steveshanks ( ) posted Sun, 16 March 2003 at 11:58 AM
I have to disagree with you very very strongly BT (but in a nice way ;o), if a person poses the buttocks then the cloth must conform to it, especially with V3 having such long ones...email looks to be down at the moment Taura but i'll get them soon...thanks, Steve
brycetech ( ) posted Sun, 16 March 2003 at 12:27 PM
lol ok, make a skirt and give it buttocks instead of thighs ...then get back to me :) BT
steveshanks ( ) posted Sun, 16 March 2003 at 12:41 PM
Yes skirts, but this is pants ;o)...No buttocks in skirts are a compromise for the no 3 group problem in poser but if you make sure you only have one point in the 3 groups buttocks are fine....grab the free model from poserworld it has buttocks in...Steve
Taura Noxx ( ) posted Sun, 16 March 2003 at 4:12 PM
well I just thought that it would be buttocks because the thigh parts didn't match the mesh. But then I thought that if you moved the thighs that some of the buttocks move with it too, like in the fall off zone or something. To be honest I have tried making my last pair of shorts with no buttocks and the mesh just splits between the hips and thigh parts when conformed so I usually add buttocks in. I don't know why it does that, but like I have said before, I really don't know what I am talking about so I could and most likely be wrong.
